1200 ute ca18det project
From NSW
i am thinking about selling my beloved 1200 ute project.. i have recently been reassigned overseas for work and dont see any point in holding on to the ute.. i am going to try and list everything as best as possible. i have included a pic of just before it went off to the body shop..
- 1974 Datsun 1200 ute - complete shell, inc. panels, doors, windscreen (front and back) and windows.. Body is pretty good, straight and nearly no rust (apart from surface after recent paint strip treatment).. has a modified front apron and radiator support to fit custom made intercooler (behind the apron and grill), and also has the tornau cover hooks and tailgate latches cut off in preparation to be shaved and cleaned up.. purchased for $1500.00, have spent another $800.00 on minor body work that has started as mentioned..
- CA18DET number 1 - mostly complete engine removed from a 1200 ute (previous conversion), has been pulled apart and checked/cleaned. It has an upgraded brand new 6 boost top mount manifold along with a garret gt3076r turbo and turbosmart wastegate. the plenum and rocker covers have been polished and had some minor modification done to fit braided hoses. turbo manifold is ceramic coated along with the snail on the turbo (over $5000.00 spent)
- along with the above mentioned i have had a custom made radiator, (with catch/overflow can and pro street spec thermo fan), and a custom made intercooler, along with all the piping, and a custom made dump pipe as well. (over $3500.00 spent)
- CA18DET number 2 - i bought this as a spare engine. it came out of a working 180sx but has low compression on the 3rd cylender, would suit rebuild or spare parts.. ($350.00 spent)
- reconditioned (by maddat) r31 stumpy gearbox with ca bell housing (aprox $550.00 inc gearbox and mods)
- r31 rear LSD diff, shortened and resplined (aprox $1500.00 inc diff and mods)
- r31 front struts (modified by maddat to suite 1200), also have slotted rotors (aprox $500.00 inc mods)
- top (tri bar) and bottom sway braces (maddat) $670.00
- rebuilt front end (maddat) $595.00
- short throw shifter (maddat) $120.00
- brake booster master bracket and clutch (maddat) $780.00
- heavy duty clutch pedal (maddat) $80.00
- lowered rear springs and adjustable koni shocks (maddat) $880.00
- engine and gearbox x member kit (maddat) $540.00
- front bumper used (aprox $75.00)
- garret turbo blanket (aprox $100.00)
- new plastic grill
- custom made stainless steel grill
- CA18DET power steering pump (aprox $180.00)
- 2 x heater boxes used
- 2 x pedal boxes used
- 3 x various dash instrument cluster surround
- 1 x center console (i think its from a coupe)
- 2 x set of 4 trx wheels used (aprox $1000.00) 1 set good 1 set not so good
- 2 x new non genuine front guards (aprox $120.00)
- 1 x central locking kit (aprox $140.00)
- 1 x electric window kit (aprox $90.00)
- new AA Gasket kit for CA18DET
- new set of bonnet hinges (aprox $30.00)
- new boss kit (aprox $45.00)
- collapsable steering colum supplied by maddat (aprox $175.00)
- fibre glass door and kick panels (aprox $50.00)
- dash frame
- set of seat rails (slightly modified to suit sparco seat mounting holes)
- Following brand new sparco gear
- 2 x sparco R100 sky seats black
- 1 x sparco volante p104 sport steering wheel
- 2 x sparco 4 point harness black
- 1 x set of sparco settanta series gear knob and boot, handbrake handle and foot pedals
- 1 x sparco p260 steering wheel (bit small to use)
- 1 x polished small fire extinguisher
sparco total - over $2000.00
total outlay so far as you can see is over $20,000.00, not to mention how much time has gone into this car.
i am looking to see if anyone is interested in buying as is still needing the body and paint done and then being assembled. as you can see almost everything you need is there..
i am not looking to get back every single dollar spent but looking to salvage what i can before i head overseas. if not i will put it in storage..
open to reasonable offers. pm me if interested. i am away for a week as of tomorrow so please leave your contact info and i will be in touch when i return.
p.s. had a few pm's on selling parts but i am not interested in parting it out as i will be keeping the project in storage unless i can sell the whole lot.. i am happy to sell all parts and keep the shell..
Posted on: 2014/12/1 6:29
Edited by DON_1200 on 2014/12/1 7:23:15
Edited by DON_1200 on 2014/12/1 7:23:44
Edited by DON_1200 on 2014/12/21 6:07:51
Re: 1200 ute ca18det project
If you change your mind I am interested in brake booster and ca fitting kit
Posted on: 2014/12/2 2:28
datsun a15 ute
From NSW
Bump.. had many enquiries.. pricing guide is around $13000.00 incase your wondering. call, txt or pm if interested. adam 0417495995.
Posted on: 2014/12/21 6:10
Your confused ,i'm confused, lets all be confused together and agree that i'm an Ebay clutz
D
Posted on: 2014/12/21 19:55
Are you worried about Testking 70-336 dumps exam testking.us preparation? We offer up-to-dated www.hood.edu
