A14 Run in?
From Brisbane Qld
Guys my A14 I got on the road a few weeks ago Its a mild rebuild
1ml over size pistons and a good cam. I was told to do a bit of hill work to labour bit to bed rings in.
Well I did a fair bit of that. But when I 1st had it going we found my elec dizzy to be no good.
So went back to points.
But my 1st drive of it was running Like #OOPS# like it was on 3.
And that was over 100k,s round trip to get back to Mechanic.
After that still did run real good for a while till after I had
Done the 1st 1000ks and did the big svs. Tuned it a bit better but still pined a little under Load..
So my fear is that One I gave it a bit of a rough time reving to high in the 1st 500 and I didn't do the uneven speed's on high way Driving as some one else told me about that NOT MY MECHANIC?
So Its Still not 100% But a lot better after buying new carbie..
I would hope not have to Pull it down again
Or maybe I could use my Holly fuel pump and get it tuned on the dyno? I just Don't want to #OOPS# it up it has good power after 3000 revs
Posted on: 2014/12/22 20:07
Re: A14 Run in?
From Melbourne, Australia
You consistanly come on here and complain about having a crap tune
Get a new mechanic or stop f'n around with it or get efi or something. Whatever you have been doing isnt working!
Posted on: 2014/12/22 20:37
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: A14 Run in?
From Gone to Maui
The run-in method is not so important nowadays. Back in the 1970s it was important but with today's oils and metals, it doesn't matter much.
What problem are you having? If it is just "pinging" then it is a simple distributor timing adjustment.
Posted on: 2014/12/22 21:22
Re: A14 Run in?
From Brisbane Qld
Thank David always a smart And Polite answer.
As the Other. Well iam finished with the Both old Mechanic's
Only Because I am Moving up North.
But Their were Both Great Mechanic's that Hade very fair prices.
The car was just hard to tune with The dizzy that Was a so called E15
eclectic one Witch was wrong it was To long And I might I add I got
that from a member on hear. And with the #OOPS# carbie to. Witch all so was
no good that came from Hear To. So I will never Buy nothing from hear site un seen Ever again
ANY HAVFE A MERRY XMAS DAVID
Posted on: 2014/12/23 0:19
Re: A14 Run in?
Not too shy to talk
From South Africa
Driving the engine like a sissy is what causes damage while running in.
Posted on: 2014/12/28 21:10
Re: A14 Run in?
From Gone to Maui
Yes, driving it easy after a engine rebuild increases the chance that the rings will never properly seat, resulting in oil use/smoking forever after. Driving it normal will be OK.
Posted on: 2014/12/29 0:01
Re: A14 Run in?
From Brisbane Qld
Well I did not baby it that's for shore I put a heavy Oil in on the 1st big
Svs one of mechanic said that oil would be good in Hot weather this other old guy
said it was to heavy and would make it work to Hard I think I will take it out after
I tell you what it is Because its not ruing that well now I want to get to Bundy
and see the carbie guy and get it back elec dizzy to
Posted on: 2014/12/29 0:56
Re: A14 Run in?
From Gone to Maui
Heavy oils like 10W-40 or even 20W-50 are perfectly fine because of the multiweight rating. It'll flow like a thin 10 weight or 20 weight at temperatures below freezing, yet flows normal even at 100C+ degree engine temperature. Nissan recommends both for the A14 (see chart).
Yes, a good running carburetor will make the car a joy to drive once again.
Posted on: 2014/12/29 1:06
Re: A14 Run in?
From Brisbane Qld
Great thanks David I so wish I was in the USA Or maybe you would Not
Lol I would come to see you a lot With my Datsun issues
Posted on: 2014/12/29 11:36
Re: A14 Run in?
Not too shy to talk
From South Africa
Run in oil I use SAE30/40 on all the engines I build.
The cheapest you can find :)
Posted on: 2014/12/30 6:57
