a12 m2 engine welsch plugs
From sydney
Hey guys recently bought my first datsun a 1200 sedan
it has a a12 engine but it's not the original one and it was m2 in thr block and extra welsh plug trying to find the size for it and whats the difference apart from a lightened crank
Did a little sesearch but thought id ask
thanks
Posted on: 2014/12/31 3:08
Re: a12 m2 engine welsch plugs
Newer A12 used an M block. There is no difference between it and a 120Y block, except for the water inlet tube and block breather tube.
Posted on: 2014/12/31 4:26
From sydney
im trying to figure out how to post a photo from my phone to show you even has a nother bolt in the block next to the other one
Posted on: 2014/12/31 5:23
From sydney
jpg  photo_php.jpg (5.79 KB)
18118_54a389bc05af0.jpg 177X133 px
Posted on: 2014/12/31 5:36
Yes, I see what you mean. Here is an original H10 (Datsun 1200) block to compare. I see what look like two drain plugs in your photo, but only one in the H10 block.
What is the casting number on your block?
jpg  19179.jpg (19.78 KB)
174_54a3ad4841258.jpg 498X202 px
Posted on: 2014/12/31 8:01
From sydney
Says the model is a12 but has a big m2 embroidered into thr block on the same side as the welch plugs
and its alot smaller then the normal 35 mm messaures to about 25mm
Posted on: 2014/12/31 8:33
I'm not too sure about the validity of the M2 block containing a lighter, scalloped crank, I have come across many with just the normal crank.
Would you happen to have a picture of the A12 M2 crankshaft in your engine?
Posted on: 2014/12/31 8:52
Regarding the 'extra' on the M2 It looks like another threaded port into the side of the block.
Posted on: 2014/12/31 8:56
There were also older M08 blocks for A12 engine, but they did not have two plug bosses, at least not the ones I've seen. They are identical to Datsun 1200 block as far as I can tell except for the bolt on parts like oil pan, water input tube, etc.
1971 M08 block
Posted on: 2014/12/31 9:03
It isn't an additional port for a cold preheat plug? Used in cold climates to de-ice the block coolant?
Posted on: 2014/12/31 9:05
