« 1 (2)
Re: a12 m2 engine welsch plugs
Well I think all new-style (1974 and newer) A12s have two bosses, but usually only one of them is drilled for a drain plug.
* New A12 has offset middle core plug (same as original A12), but with two drain plug bosses. Usually only one is drilled & tapped for a plug.
* A14 has centered middle core plug and single drain plug boss
Here is an M22(?) block A12 engine. Notice it has the new-style motor mounts (it is a mid-dizzy engine).
If this block is fitted to a Datsun 1200, the motor mounts need to be modified or a short/tall crossmember fitted.
Posted on: 2014/12/31 10:30
... the welch plugs and its alot smaller then the normal 35 mm messaures to about 25mm
Haven't come across that before. Even the last 1994 A12 used 35mm welch plugs.
Posted on: 2014/12/31 11:12
From sydney
that block looks the exact same with the back welch plugs and bolts
and the dizzy is mid mounted id say with a electronic dizzy aswell
the last owner didnt know much and he bought it like this
jpg  m2 block.jpg (151.14 KB)
18118_54a4789c3b5b6.jpg 960X720 px
Posted on: 2014/12/31 22:29
From sydney
and this is the engine bay
jpg  1200 engine.jpg (116.54 KB)
18118_54a478d914065.jpg 720X960 px
Posted on: 2014/12/31 22:30
From sydney
and no picture of the crank i actually just put the sump back on im affraid
Re: a12 m2 engine crankshaft
All newer A12s have a lightened (scalloped) crank, starting with cranks made October 1979, as in B310 Sunny, N10 Pulsar, 1200 ute, and C120 Vanette.
'M2' blocks reportedly are factory replacement blocks and if so, they would have the newest components. The new A12 crank is even sold by Nissan USA (part number 12200-H8560).
Replacement A12 crank
Original A12 crank
Posted on: 2015/1/2 5:30
RE: Welch plugs
Per all the Nissan parts catalog the welch plugs haven't changed size. I looked in these catalogs: B10, B110, B210, B310 USA, B310 Japan 1982, E10 1974, N10 1982, C120, C22, B120 1994.
That being said, I found some welch plug sets for "120Y" and "140Y" that
show different size plugs.
See Welch Plug section "Sets"
Posted on: 2015/1/2 5:37
From sydney
sweet as
thanks mate
Posted on: 2015/1/5 10:51
« 1 (2)
