HP of A14E fuel injected motor
A14 type engine - factory HP & torque graph.
A14 : 80 PS @ 6000 RPM
A14E: 92 PS @ 6400 RPM
PS is german horsepower rating, which is very close to SAE HP.
It uses a GX-like camshaft to achieve this power (longest duration cam of factory A-series). And probably helped by the tuned intake runners, because the head ports are not as large as a GX engine. Compression is same as regular A14 at 9:1.
jpg  EGI.jpg (88.01 KB)
174_54bb6429d7b05.jpg 909X961 px
Posted on: 2015/1/18 7:43
Re: HP of A14E fuel injected motor
Torque
A14 : 11.5 kg/m @ 3600 RPM
A14E: 11.7 kg/m @ 3600 RPM
so no loss or torque, and still they widened the powerband.
Posted on: 2015/1/18 7:51
From Kelmscott Western Australia
I got a new egi cam in the box
Found the specs of it
Same specs as the gx
Posted on: 2015/1/18 8:03
71 Datsun 1200 ute with A14 fuel injection and T50
59 Morris minor ute with A15 fuel injected with intercooled turbo
The EGI A-Engine featured the best flowing A-series exhaust manifold as well.
There have been at least four different types of manifolds used on the A-Engine EGI series.
Posted on: 2015/1/18 8:27
Re: exhaust of A14E fuel injected motor
B310 A14E 14004-H9200 MANIFOLD-EXHAUST - Single Outlet
B310 A15E 14004-H9260 MANIFOLD-EXHAUST - Dual Outlet
N10 A14E 14004-M7300 - Single Outlet
A14E 14004-H9200 MANIFOLD-EXHAUST internally a 4-into-2
A15E 14004-H9260 Dual-outlet (cast 'H926')
Posted on: 2015/1/18 8:39
Okay, there is one more that points right toward the ground, meaning the flange face is parallel with the road surface.
I wonder how much the exhaust manifolds contribute to the substantial power increase.
Posted on: 2015/1/18 8:42
That first manifold pictured looks like it would work particularly well.
The last manifold pictured is reminiscent of the infamous GX & T series (& not so infamous KB10) twin outlet with a few subtle changes.
Posted on: 2015/1/18 8:50
Not huge strides of development but you can certainly see the improvement.
Posted on: 2015/1/18 9:00
I wonder if 100hp was possible with higher 10.5:1 compression A15E
but also match porting these ugly casted manifolds?
im sure the Hyundai version is prob better for availability and flow
http://datsun1200.com/uploads/photos/21775.jpg
Posted on: 2015/1/18 12:37
