« 1 (2)
Re: BW 60 series diff into BW 68 series diff
From Coondle, WA Australia
Its a bit hard DD to clearly read the seal number
Since its a Borg Warner diff, its different from the Hitachi stuff.
Axle shaft diameter - 30mm
bearing OD - 60mm
The only markings I can find are on the axle seal - Plaseal 18557
Posted on: 2014/12/17 12:56
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Since the axle diameter is 30 mm -- the same as an early made-in-Japan axle -- you can use a standard Datsun 1000/1200 retainer.
RockAuto.com
CAUTION: It is a different thickness than the BW retainer, so if the seal goes over the retainer, the seal would need to be different, or the correct BW size retainer should be used.
The standard 1200 seal is for a 41 mm O.D. retainer (1.6 inch).
18557 is a standard seal:
* width: 0.313 inch
* Bore: 2.471 inch
* shaft size: 1.875 inch
Posted on: 2014/12/17 20:46
Thanks for that DD
I'm heading down to the shop today to pick up the bits.
ill let you know how it all goes
Thanks
Posted on: 2014/12/18 1:58
Well the whole project was very successful.
The bearings that I was supplied were slightly different than the ones that came off the axles, but they fitted fine none the less.
They were slightly longer and used a small o-ring to help seal around the housing. The old ones were a interference fit only.
Regardless, they fitted in fine, and the diff/housing is back together and new owner is happy with the end product.
Thanks DD for the help
Posted on: 2014/12/30 3:50
Glad to hear it worked out OK. What was the part number of the new bearings?
Posted on: 2014/12/30 4:26
sorry for the late reply DD.
It was a Timken kit, but I didn't get the numbers from the bearing before it went in.
All I have is the part # from the supplier which wont be of much use to anyone outside of Australia, but for reference.
Statewide Bearings - 2742 Wheel bearing kit. Contains new bearing and retainer plate.
Posted on: 2015/1/19 3:04
Thanks that actually does help.
Statewide's catalog says:
Rear wheel bearing 2742
* Datsun 1200 Borg Warner axle - for most B110 Series Sedans 1970-1974
* Datsun 120Y Borg Warner axle 1974-1975
* CAPRI RWD 1972-1974 (Excluding Salisbury diff or V6)
* CORTINA Mk11 1968-1973 (Excl Salisbury Diff)
* ESCORT 1100,1300,1600, GT 1970-1976
* ESCORT TWIN CAM 1970-1971
* RS2000 MK11 1978-1982
* MkII 1976-1982 (Excluding RS 2000)
* MARINA Australian Production 1972-1975
* COROLLA KE30,KE35,KE36,KE38,KE50,KE55 Borg Warner rear axle 1974-1981
* CORONA RT40,RT41 Sedan Borg Warner rear axle 1965-1970
Posted on: 2015/1/19 4:44
From Perth
2742 contains a bearing # 411546R (30mm x 62mm) and an R3 (206R) collar 29.85mm id 46mm od 9mm wide
Posted on: 2015/1/19 9:55
From Freo
see, some clever people here, work things out... make things happen...
Posted on: 2015/1/19 10:03
A15 PSI Project Motor
'72 CB750k,
Thank heavens for them, else id be in real trouble.
It didn't help that my primary source of info was off gallivanting around the world, and not at my beck and call 24/7.... cheeky bugger
Posted on: 2015/1/19 10:10
« 1 (2)
