1000 engine with 63-series gearbox
Looks like a F4W63L gearbox
jpg  img_5.jpg (57.61 KB)
174_54be1545c799d.jpg 512X320 px
Posted on: 2015/1/20 8:43
Re: 1000 engine with 63-series gearbox
From Coondle, WA Australia
Not that I want to question the guru round here, but you sure its an a10?
The exhaust manifold is curved and the thou one is squarish.
I'm sure the starter motor should be on the other side.
Those engine mounts are just plain weird.
The fry pan uses those side clips. All my fry pans use a nut in the centre to wind it down.
The fry pan is on a strange angle and the handle should point over the rocker cover
The sump plug is in the wrong spot as well. A thou sump plug is in the bottom of the hump, not the side.
And what is with the rocker cover? What's that hole at the front?
As for the gearbox, it almost looks like an auto box with that big flat bottom.
Posted on: 2015/1/21 10:43
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
You may be right about the engine.
Datsun 63-series 4-speeds (for example, 1300 utes and 1600 sedans) have a bottom pan like that.
Posted on: 2015/1/22 4:12
Datsun 63-series 4-speed gearbox
4-speeds came with bottom pan (FSW63L old style) or without bottom pan (FSW63B new style). 5-speeds never came a bottom pan.
Posted on: 2015/1/22 5:16
From Kelmscott Western Australia
This is j series
Posted on: 2015/1/23 10:57
71 Datsun 1200 ute with A14 fuel injection and T50
59 Morris minor ute with A15 fuel injected with intercooled turbo
