Browsing this Thread:
1 Anonymous Users
Stuttering of engine. 1973 120y B110 series |
From South Africa
I recently got myself a Datto but there seems to be something wrong on the carb as to my knowledge, it creates a stuttering effect and kills the engine. The problem also occurs when i drive and reaching a certain rev point. If anyone could help??
Its an urgent matter
Much appreciated
Posted on: 2015/2/2 23:25
Re: Stuttering of engine. 1973 120y B110 series |
Registered Users Contentmaster Usermaster
Most often caused by a spark problem. I would sand the ignition points, re-gap them, then adjust the dwell.
Posted on: 2015/2/3 1:01
Not too shy to talk
Does the carby have a glass window in it? If it does drive the car and when it the engine stops check the window and see if there is any fuel in it. If there isn't its fuel related, if there is it a spark issue. I had a similar issue and it was blocked fuel line.
Posted on: 2015/2/3 1:31
From South Africa
Thanks guys, only online today, will have a look when i get home! I appreciate it.
Thanks again
Posted on: 2015/2/3 21:41
