Up-rating a stock engine
Hey fella's, I am prepping an old Datsun 310 for a local chump car race, and would like some input.
I am thinking of milling the head for a compression boost and possibly changing the cam timing a few degrees.
How far can I mill the head before I have problems with the rocker geometry and piston clearance. Suggestions on cam timing? what do you use for push rods if they need to be shorter.
I will clean and match ports, and freshen the bottom end while it is down..
Any ideas will be appreciated.
Thanks,
Mongo
Posted on: 2015/2/9 0:38
Re: Up-rating a stock engine
If its an old Datsun 310 with 1200 engine, it can be shaved 0.030 inch, use the stock push rods.
If its a Datsun 310 with SOHC engine, it can be milled 0.060 and it wont have pushrods.
Or if its a 310 with OHV engine it can be shaved 0.080". Use custom push rod ends on Chevy pushrods cut to Length. You can gain a solid 2 HP from this work. Unless its a 5-speed car, in which case only 1 hp.
Posted on: 2015/2/9 1:33
From Las Vegas USA
Note that you on an A-series that there are different thickness head gaskets which will raise the compression about a point or so. Delta cams in Tacoma Washington will regrind a cam for $75 and they are quite familiar with A-series.
Tom
Posted on: 2015/2/9 4:50
Its got an a-14 and 4spd.
any idea where to get the push rod ends?
Piston to valve clearance worries?
Posted on: 2015/2/9 6:27
Yes, click the pushrod link in the prior reply and contact any of the push rod companies listed
Yes piston to valve clearance is always a concern so measure it.
Posted on: 2015/2/9 6:49
Makes a good race car, super reliable and if it rains you got the FWD advantage.
Posted on: 2015/2/9 6:53
Got another question. Will a E-series flywheel bolt up to a a-series engine?
I am wondering if the later FWD trany can be used in a 1980 310.
Thanks for info fella's
Posted on: 2015/2/11 16:50
Good question.
I would ask at http://forum.pulsar.org.au, the FWD specialists. Ask about the N10 model series which is what a 1979-1982 310 is.
Posted on: 2015/2/11 21:22
