Ignition Issue
From Sri Lanka
Hi Guys
I had an ignition issue on my b310, Suddenly car had a huge Backfire from tail pipe and it
was noisy like a cracker, and then car died while driving, could start it again but had a miss, and i stopped it ignition coil was extra hot , so kept it 30 minutes tried to start it did not ,then checked the ignition while cranking for first few cranks no ignition after that it gived ignition ? why is that ? after cranking 5 cranks i could start it and came home pulling was normal but when idles it tends to die soon. managed to come home after i come home i stopped it sand started it it started once also ,what do you guys think ? is it my ignition condenser ? i have replace my ignition coil 1 month back only, almost all the ignition parts are new
thanks
regards
sumith
Posted on: 2015/2/16 3:33
Re: Ignition Issue
Maybe it is the condenser. Install the old one and see if it improve
Several of us have experienced those symptoms, where the cause was a loose.wire at or inside, the distributor.
Posted on: 2015/2/16 4:12
Re: Ignition Issue
From Sri Lanka
Hi DD
Thanks i will check it
regards
sumith
Posted on: 2015/2/16 4:21
