Nice A14 for sale - California, not mine.
Posted on: 2015/2/17 13:15
Re: Nice A14 for sale - California, not mine.
If that Morris World alloy rocker cover comes with it, all is good.
* H89 cylinder head
* Weber 32/36 carburetor
Has an unusual custom sump, but a stock pan can be swapped on easy enough.
jpg  DSCN3301-L.jpg (157.76 KB)
174_54e3dd31b31c2.jpg 800X600 px
jpg  DSCN3784-L.jpg (129.37 KB)
174_54e3dd533a3c0.jpg 800X600 px
jpg  DSCN3286-L.jpg (128.91 KB)
174_54e3dd7091c32.jpg 800X600 px
jpg  DSCN2285-L.jpg (145.56 KB)
174_54e3dd7ab4ce9.jpg 800X600 px
jpg  DSCN3294-L.jpg (130.17 KB)
174_54e3dd851f1f6.jpg 800X600 px
Posted on: 2015/2/18 0:30
From Cambria, California
Nice! And its just down the road from me. The list price of the custom rocker cover and Weber conversion alone are at the asking price of this engine. Too bad he didn't hot rod the A14 with pistons, cam, headers and Weber side draughts...then he'd have no need to install the Miata engine.
Posted on: 2015/2/18 1:36
Agreed.
On second thought, that appears to be a USA B210 oil pan. It has a mid-sump so you can fit it into a 510 (1600).
Posted on: 2015/2/18 2:13
Not too shy to talk
From Garden Grove, Ca. USA
Do you know where I could get that done on an A14? We live in Garden Grove Ca. Have owned a '72,1200 for 33 years. A few days ago broke a rod bearing in our A12A. Don't want to rebuild but put an A14 in it. Being practically run off the freeway with it because it can't sustain high speeds.
Posted on: 2015/2/20 6:17
Not too shy to talk
We live in Garden Grove, Ca. Where could I get that done on an A14? We just broke a rod bearing in our '72, 1200, A12A we've owned for 33 yrs. Need more power on he freeways.
Posted on: 2015/2/20 6:21
Get that done? Just buy that A14 - it cost less than paying someone to do the same to your A14, and its already done. But it won't go faster than an A12. My stock A12 had no problem doing 75 MPH on the LA freeways. Sure it ran 4500-5000 rpm, but t hat doesn't hurt an A12 (redline is 6000 rpm). If you put the A14 in your 1200 it will still need to rev to the same RPM. You can fit an overdrive transmission to lower the rpms, but getting to higher speeds still means accelerating in 4th gear. Then once you get up to speed, shift into 5th for quieter cruising.
Posted on: 2015/2/20 6:54
Have you seen the replies to your previous posts? Click your name to see your posts.
Posted on: 2015/2/20 6:56
