« 1 (2) 3 4 5 »
Re: SR20DE Dizzy conversion
From Creswell, Oregon USA
Yeah my DOHC A12 is on hold while the car is returned to the road this summer. Once the car is to my liking (drivable and painted) I plan to finish the DOHC project with the 1.5 Mazda Z head.
Posted on: 2015/2/28 6:41
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
Will u take photos of the CAS conversion?
Posted on: 2015/2/28 7:16
By the way, they say never unbolt the Optical head from the CAS - even though there are two little screws it may break it. Instead, unbolt the center screw then flip the wheel over.
Posted on: 2015/2/28 7:48
Posted on: 2015/3/1 1:38
Parler @MDMachine
Posted on: 2015/3/1 1:42
I will have to shorten the SR drive shaft to allow for a good mesh of the A12 gear with the CAM drive.
Then I need to machine a spacer as you can see the output portion on the A12 dizzy is shorter than the SR body.
All this for getting it aligned right.
Posted on: 2015/3/1 1:46
Parler @MDMachine
Dion120Y was selling SR20 CAS
converted for use with A-series engine
Posted on: 2015/3/1 2:22
Yes, and I wish he had done a write up.
Posted on: 2015/3/1 6:26
Parler @MDMachine
The one I got for $12.50 at pick-n-pull sale bolted right in an A12. Just needed gear swap to make it turn. No other modifications or cutting/grinding needed. It was from a B12 Sentra with E16I engine.
Posted on: 2015/3/1 7:13
Hmmm.
Too late I'm committed ;)
I will have to look into this.
Posted on: 2015/3/1 13:46
Parler @MDMachine
« 1 (2) 3 4 5 »
