« 1 2 (3) 4 5 »
Re: SR20DE Dizzy conversion
Sounds like it is gonna be nice! Got any pics? Last I heard you were doing bike carbs?
Posted on: 2015/3/1 21:33
From Creswell, Oregon USA
I got those too.
Set of R6 carbs. Just can't find an adequate carbon filament 3D printer for making the intake bits. Little more complex than my mill can machine out.
Posted on: 2015/3/2 0:23
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
Once the mods to the casting are done, What do I do to time the Holographic Disc to the TDC of the CAM, Crank, and Compression of Cyl-1?
Posted on: 2015/3/2 20:06
Parler @MDMachine
For that information you will need an SR20DET repair manual. It will explained how to time the CAS sensor. Probably something like "turn the engine to TDC for #1 cylinder, then insert the CAS" with a certain mark on the wheel in a certain position.
Posted on: 2015/3/2 21:07
I was headed that way but thought I would ask.
Thank you for the direction.
Posted on: 2015/3/2 21:30
Parler @MDMachine
You can look at a Sentra or Infiniti manual at the library. The SrR20DE procedure will be listed.
Posted on: 2015/3/2 21:37
This video helped give me a clue
http://youtu.be/sYBHLjY4sRw
Posted on: 2015/3/3 3:12
Parler @MDMachine
Yo! It's worksnaDELUXE!
Posted on: 2015/3/11 23:00
From Sydney, NSW
How did that all go for you? I'd love more info as I'm looking to use something like a d4p for spark for efi
Posted on: 2016/1/11 22:41
I need to take the time and show how I modded my SR20DE CAS.
Its a lengthy mod though. have to re-machine some of the parts.
Posted on: 2016/1/11 23:51
Parler @MDMachine
« 1 2 (3) 4 5 »
