Parts from Nissan?
Quite a regular
From Sydney
I was just reading up on part numbers and etc.
I need a rocker cover gasket and a lock & key for the fuel filler door. I have a 1984 Ute, but all I could find were part numbers for 71-73 B110. And borderline nothing for Nissan AUS. Can I still get these parts at a Nissan dealership or?
Thanks, any help is appreciated.
Posted on: 2015/3/22 6:59
Re: Parts from Nissan?
Nissan Australia uses the same part numbers. But just like Nissan dealers here, may or may not want to order them for you.
Rocker Cover gasket is still available.
Lock is not available in USA, but perhaps can be ordered from Japan. Very few dealers will even try. But there are some here who will.
Key is available, but any Datsun key will open the fuel filler door (the tumbler is not keyed).
Posted on: 2015/3/22 8:34
Rocker Cover gasket same part number in Japan, USA, Europe
http://www.nissanpartsdeal.com/parts/ ... et-cover~13270-h1000.html
Posted on: 2015/3/22 8:45
Re: lock & key for the fuel filler door from Nissan?
1984 Ute uses the standard double-sided Datsun key?
Type B in diagram from Key Part Numbers is for Japan 1984 B120
http://www.courtesyparts.com/key-blank-p-520075.html
1984 fuel door lock forJapan
76960-H4700 CYLINDER SET-GAS FILLER LOCK 7510-
Not available in USA although the B110 one I think will work
http://nissan.dealerdirectparts.com/N ... 0-H1001-p/76960-h1001.htm
Posted on: 2015/3/22 9:00
From Gold Coast Queensland, Australia
If you absolutely need oem parts check here http://www.new-datsun-parts.com/datsun-1200-parts-locks.html
otherwise ebay has lots of after market parts
Posted on: 2015/3/22 9:36
1200 ute
L20b
From Kelmscott Western Australia
Bprojects
Posted on: 2015/3/22 10:32
71 Datsun 1200 ute with A14 fuel injection and T50
59 Morris minor ute with A15 fuel injected with intercooled turbo
From Central coast NSW
Chase up the parts u need and do the research and u'll get the best price...
Posted on: 2015/3/22 10:35
Quite a regular
From Sydney
Bprojects Ebay seems to have everything I need. Whether they are expensive or not i'm not too sure. Thanks for the help.
Posted on: 2015/3/22 10:53
Nissan sells the 3 parts you listed at 1/4 the price. Although after the AU tariff maybe only 1/2 the price.
Posted on: 2015/3/22 10:58
From sydney
hi,beeonetwenty
i bought a genuine fuel lock for a ute from Nissan back in 2012.
the part number is NI-76960-H5005 for the lock and NI-76962-18200 for the clip.
hope this helps you out.
thanks
Posted on: 2015/3/23 2:17
