Browsing this Thread:
1 Anonymous Users
H165 lsd |
From Port Douglas. QLD
anyone brought and installed an lsd for the h165 from component restorations/sonitora works? If so did you install yourselves?
Posted on: 2015/4/5 4:17
1200 ute ca18det
Re: H165 lsd |
From Victoria
No but I have a KAAZ in mine.
Posted on: 2015/4/5 8:50
Re: H165 lsd |
From Gold Coast, Australia
use a zenki ae86 lsd. then use imperial bearings to fit the centre housing, I can give you the part numbers if you like. some machining is required. but works a treat. you don't compromise one journal size when using the bearing I used.
Posted on: 2015/4/5 11:29
Re: H165 lsd |
From Sydney NSW
Interesting option with the AE86.
What is the restorations charging you for h 165 LSD?
Posted on: 2015/4/5 12:50
There maybe faster ways to go... But I'm never in a rush
Re: H165 lsd |
Registered Users Contentmaster Usermaster
TRD 41301-TA005 requires no matching, just special stepped bolts. About $850 TRD LSD for H165
Posted on: 2015/4/5 20:30
