A14 with 5 speed?
Not selling quite yet, but I am trying to figure out about how much an A14 with a 5 speed with webber 32/36 carb might be worth. I have a KA24DE that I could put into my roadster, or into another roadster I have. I'm trying to decide if it is worth rebuilding the A14 and selling it or not.
Thanks in Advance,
Posted on: 2015/4/9 17:46
Re: A14 with 5 speed?
Maybe $1900?
Posted on: 2015/4/9 20:59
From Penrith, Sydney, NSW
About 1500-1700. Maybe more but depends where you are located too. If in sydney probably a bit more as more demand. Also if people dont have to ship or travel to pick up then they may pay more.
If you do go ahead and sell it whether rebuilt or not send me a pm as i will definitely be interested.
Thanks
Trav
Posted on: 2015/4/9 22:10
"If the doors of perception were cleansed, every thing would appear to man as it is......infinite"
From south coast nsw
A used a14 + 56a was on gumtree for 200 bucks the other day. Didn't last long but.
Posted on: 2015/4/10 2:35
Depends whether you have a 5 speed normal shift pattern or dogleg pattern. I would imagine that the normal shift pattern is worth more.
Posted on: 2015/4/10 2:37
Thanks for the feedback. The stick is normal. I am in the LA area. I'll probably make my decision after the roadster get together in solvang later this month. Thanks again!
Posted on: 2015/4/10 17:31
Los Angeles?
Its worth $1000 maximum.
Posted on: 2015/4/10 19:35
Hmmm, interesting spread on value. I ran the compression test on it today (the right way this time) and its doing 150 psi on each cylinder. Turns out it might not need that rebuild after all! although, I think the rear main seal may be having issue. It also turns out that the plug wires were not working properly. Now that I replaced them the performance is much better.
Thanks again for all the info
Posted on: 2015/4/10 21:31
I figured you were from another country. This site is based in Europe.
In USA, five-speeds are relatively plentiful. And so are A14s. So the prices are much lower.
* B210 dive-speed
Posted on: 2015/4/10 21:40
* B210 five-speed $350
* 210 straight pattern 5-spd $600
* pick-n-pull 5-spd $140
That's with 30-day guarantee
Posted on: 2015/4/10 21:43
