« 1 ... 63 64 65 (66) 67 68 69 ... 97 »
Re: Super Bee KA24DR Mod
From Snohomish, WA USA
Car is running now. Transmission took 7 1/2 quarts of fluid. Normal 9-10 but the torque converter is so small. Transbrake works but really didn't get to run it.
The exhaust needs to be hooked back up. So I trailered it done to the muffler shop.
They said they were swamped but would try and get it done. I'm one of there regular customers. They do all my aluminum welding.
Hopeful I have time tomorrow to tune it otherwise I'll be doing it at the track.
Other than that all I just need to do is get the carpet and seat in on the passenger side.
Ill post some pictures after I get the car back.
Posted on: 2015/4/16 18:10
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Love Hate relationship.
First run of the night was great at first.
Heated tires in the burnbox, staged at the lights, set the trans brake and launch off the line with a 125hp shot of wet Nitrous, no wheel spin, stayed close behind the '64 Nova with a big block, foot to floor and slammed it into Drive. And just before the finish line, I had a backfire and ceased up the supercharger.
So its shot. Someone said I may have had the Rev. Limiter set to low and that's what did it.
I had it set at 7800 rpms.
Well when I got home I set it to the max 9900 and got on EBay and found a used supercharger $375. Should be here by the end of the week. Other then that, I have to rebuild another section of the intake since I blew it out. My blow off valve obvious was not big enough so I'm building a bigger one.
Engine was not damaged through all this carnage.
Posted on: 2015/4/20 4:29
'73 2 Door Sedan
And so coming full circle now was it fast enough for you after all the great work????
Chasing a big block makes it sound like a big YES
Posted on: 2015/4/20 5:13
Oh. Yeah my time. Still ran a 7.0 flat after coasting over the finish line with it under powered. I think I can pull a 6.0 when I get this thing figured out.
Posted on: 2015/4/20 5:34
'73 2 Door Sedan
Pictures from under the car when it was at the exhaust shop.
Tranny cooler in the rear with 2 fans mounted on top.
jpg  IMG_20150417_113039855.jpg (181.46 KB)
39_5534885111408.jpg 525X296 px
jpg  IMG_20150417_113046771.jpg (197.64 KB)
39_553488623f325.jpg 620X350 px
jpg  IMG_20150417_113111551.jpg (196.34 KB)
39_5534887400fc1.jpg 513X289 px
jpg  IMG_20150417_113142665.jpg (198.50 KB)
39_553488ac5088a.jpg 578X325 px
jpg  IMG_20150417_113133002.jpg (198.35 KB)
39_553488fcb28ea.jpg 528X297 px
Posted on: 2015/4/20 6:05
'73 2 Door Sedan
Why would shifting "too early" cause a backfire?
Posted on: 2015/4/20 6:10
I never said I shifted to early. I shifted at over 8k. When the Rpms came down was when I had the back fire.
Posted on: 2015/4/20 7:02
'73 2 Door Sedan
Sorry for my ignorance. How does a Rev Limiter set too low cause a backfire?
And how where you able to rev to more than 8000 with your limiter set to 7800?
I had a backfire and ceased up the supercharger. So its shot. Someone said I may have had the Rev. Limiter set to low and that's what did it. I had it set at 7800 rpms.
Posted on: 2015/4/20 7:24
Sorry Dave. Yes you are correct. I probably didn't rev over 7800 rpms. I just picked 8k as a number. The rev limiter will shut the ignition down and keep it from firing but I'm still pumping fuel and nitrous into the system. When the engine drops below the rev limiter it fires and that's when you get the backfire. Couple of guys at the track told me that that's what happened. They told me to get rid of the rev limiter.
Posted on: 2015/4/20 14:07
Edited by datsa73 on 2015/4/20 17:54:24
'73 2 Door Sedan
Thanks, that makes sense.
Posted on: 2015/4/20 21:01
