« 1 2 3 (4) 5 6 7 »
Re: States 1200 Coupe. (Oregon, US)
From Creswell, Oregon USA
My soon to be machined Rocker.
Posted on: 2015/4/18 6:38
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
Nice. Your design is similar to the Tomei casting.
Posted on: 2015/4/18 6:55
Don't say it too loud ;)
It's meant to be :D
Posted on: 2015/4/18 8:01
Parler @MDMachine
Almost done.
Posted on: 2015/4/23 14:31
Parler @MDMachine
Posted on: 2015/4/27 15:26
Parler @MDMachine
Looks every bit as good as a $1200 valve cover!
Posted on: 2015/4/27 22:19
From Snohomish, WA USA
Nice work. looks good!
I see the Ford 8.8 rear end. that's what I put in my car.
Posted on: 2015/5/29 13:55
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Thanks Datsa73
Did you narrow yours or have someone do it? I have gotten quotes all over the map on price to have it done.
Posted on: 2015/5/30 3:16
Parler @MDMachine
Did mine myself. Built a jig, cut and removed 5.25" off each side and welded it back together. Ordered Ford 5 Lugs from Moser. Worked slick. I did not flare so 205/60/15 fit.
Posted on: 2015/5/31 1:18
'73 2 Door Sedan
If you want to look. My 8.8 rearend build starts on page 49 of my build thread. Hope it helps.
Posted on: 2015/6/5 18:23
'73 2 Door Sedan
« 1 2 3 (4) 5 6 7 »
