Browsing this Thread:
1 Anonymous Users
Radiators |
From Freo
Hi Guys, does anyone have a GOOD contact for radiator work? it seems the rebuilding of old radiators might be a dying art, the mod of choice on a 1000 is to bung a triple core in, then it is good for whatever A series you can stuff into it, just been doing a bit of a hunt, and some of the quotes to recore are crazy,$495, $510, $550, and $650 for aluminium, I'm in Perth, but at this rate, it could be worth post...
cheers,
Posted on: 2015/4/21 23:57
Edited by Dundee1000 on 2015/4/22 11:53:31
'68 Thou Wagon,(home now) up and running '69 2 door project, the yellow thing, A12A Project motor, for the yellow thing. A15 PSI Project Motor '72 CB750k,
Re: Radiators |
Registered Users Contentmaster Usermaster
You are right, its because the cost of a new aluminum radiator is half that of a recore.
Posted on: 2015/4/22 1:07
Re: Radiators |
From melbourne
I had the same issue when i wanted my landcruiser rad recored got quote of $500-600
then i found dandy radiators they did it for $310
So if ur willing to post it to vic they should be able to do it at a reasnoble price
Posted on: 2015/4/22 1:22
Re: Radiators |
From melbourne
Posted on: 2015/4/22 1:24
Re: Radiators |
Will a 24" wide radiator fit the 1000? 1986 Golf 1.8 is triple core thickness, same height, all aluminum and very inexpensive. 1200 guys use them here.
The Champion on eBay is also popular at $200 for triple core aluminum in stock 1200 size.
Posted on: 2015/4/22 1:28
Re: Radiators |
From Kelmscott Western Australia
Used radiator factory in mannington They modded my gemini rad to suit datsun hoses and air con clearence on the bottom Give them a ring to find out what they can do
Posted on: 2015/4/22 1:30
71 Datsun 1200 ute with A14 fuel injection and T50 59 Morris minor ute with A15 fuel injected with intercooled turbo
Re: Radiators |
From Adelaide
Dunno if a 1200 one will fit but you can get an alu one brand new for 2-300 now. Wish I'd waited and done that rather than pissing around with the Civic one I bought and made fit.
Posted on: 2015/4/22 10:16
1200 Coupe A15E - ITB Lamb Daiquiri - a man's cocktail!
Re: Radiators |
From Perth
Just had the Caddy one freshened at Vic Park Radiators
There were drawings out there for an alloy one I contacted the Chinese about getting them made and they were keen once dimensions were finalised.... group buy ?
Posted on: 2015/4/22 11:15
Re: Radiators |
From Freo
thanks people, I will try some leads, the 1200 one is too high, but the 1000 one is wider, I'll measure up for the golf one,
info on 1000.com for the buy Nool....
Posted on: 2015/4/22 11:49
