« 1 ... 17 18 19 (20) 21 22 23 ... 57 »
Re: Datsunbeginner becomes an expert - Vanilla Ice ute build USA
Fooling around a bit more with my dash wiring harness.
I found a spare hazard light switch! Also found a spare heater cover that is black. Much cooler than the poo brown one I have installed.
Posted on: 2015/4/23 21:29
Black is beautiful.
Posted on: 2015/4/23 21:45
From Snohomish, WA USA
Forgot to post this photo.
Battery in the trunk. Cable up to isolator block and cable down to starter. The rest are accessories to fuse box.
jpg  IMG_20150425_195141433.jpg (188.56 KB)
39_553c64d790c1e.jpg 473X266 px
Posted on: 2015/4/26 5:10
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
So the thing mounted to your strut tower is an "isolator"? Is it the same gauge wire to the isolator block from battery and down to the starter? Looks like in the photo you have thinner wire to the starter? What is the function of the isolator?
Also what did you do for earthing wires?
Thanks for the help in advance.
Posted on: 2015/4/26 16:53
Posted on: 2015/4/26 19:12
My dash pad was in decent condition but there was a few things annoying me. There was alot of overspray/primer from the previous owner that I tried to get off with solvent but no luck. Also there is a crack running through the middle which I was going to leave there. But today I decided to repair the dash pad and fill in the crack. I used a pliable epoxy type stuff that my Dad uses for plumbing repairs and filled it in with some putty sticks and sanded it smooth. Few coats of matte black spray. So far the first pass at the repair looks okay. I am going to fill it in some more and repeat.
Posted on: 2015/4/26 23:58
Also more progress on the dash wiring. - Wiring diagram photo posted for reference for anyone using a RHD dash loom. Fuse block installed, fuses in, and wiring connected.
Also painted the ashtray to match the dash.
Posted on: 2015/4/27 0:03
Very nice work. Looks like new.
Posted on: 2015/4/27 0:08
The isolator is a gathering point for your power. It is the same function as the positive side terminal on your battery except your battery is in the trunk. Same size wire from battery to isolater to starter. For a ground, I drilled a hole in the frame up front, welded a nut to the frame and from this point I bolted #2 gauge wire to the engine and starter. Most all grounds bolt to the frame.
Posted on: 2015/4/27 5:07
'73 2 Door Sedan
Thanks guys. I will be getting the battery relocation kit soon. More questions to come.
Posted on: 2015/5/2 4:48
