Fitting shortened 200b coilovers
From Gold Coast Queensland, Australia
I'm fitting 200b coilovers to 1200 ute.
I have had trouble finding stanza/sunny steering arms but have access to 200b ones.
Then I found this thread; http://datsun1200.com/modules/newbb/v ... SC&topic_id=25177&forum=1
I now have 180b outer tierod ends as suggested.
My question is will stanza/sunny ball joints have the same taper as the 200b steering arms?
Posted on: 2015/4/21 9:06
Edited by uteboy1200 on 2015/4/22 1:38:48
1200 ute
L20b
Re: Fitting shortened 200b coilovers
From sydney australia
I've used Sunny balljoints & the taper is the same, but a spacer is usually needed under the nut on the bslljoint as that nut will run out of threads before it tightens. I have found that the Stanza balljoint is a different part, with more length between the mounting bolts & the balljoint. I don't know if the taper is different, but it will give more negative camber.
Posted on: 2015/4/25 9:09
Thanks for the input b310gx.
I have sourced sunny steering arm/knuckles as I didn't like the sound of spacers to fit the 200b arms.
The build continues....
Posted on: 2015/4/28 22:39
1200 ute
L20b
Its been a while now collecting all the necessary parts to fit these struts...
Last parts needed are Brake flex lines.
Using 200b Girlock calipers.
Do 200b flex hoses fit the 1200 hard lines to these calipers?
Posted on: 2015/7/10 7:26
1200 ute
L20b
