« 1 ... 6 7 8 (9) 10 11 »
Re: DIY GILMER Drive A-Series
Yes, 139 or 140 mm is the standard crank pulley size. What does your new pulley have to do with a Gilmer Drive?
Posted on: 2015/4/30 9:03
separate gilmer belt for blower
Posted on: 2015/4/30 11:13
From Central coast NSW
Do u have a price for v-belt crank pulley with the S/C pulley to bolt to it??
Cheers Corey
Posted on: 2015/4/30 12:55
From Quairading, Western Australia
gilmer pulleys might look nice, but I'd stick with the V belts, heard horror stories of people having problems snapping mounting bolts and other issues and getting snapped bolts out of blocks and heads is a pain in the butt... hehe
Posted on: 2015/4/30 13:00
Atheism is a non prophet orginization
From Creswell, Oregon USA
Can you make a fan pulley with a 6 rib serpentine pulley on the front half of it?
Posted on: 2015/5/1 18:34
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
fan pulley == water pump pulley
Front half -- do you mean adding a second groove to the pulley in front of the v-groove?
Posted on: 2015/5/1 19:15
I want the Fan (Water Pump Pulley) to have a 6 rib serpentine race and the traditional V on the back nearest the block.
Posted on: 2015/5/1 19:26
Parler @MDMachine
Can you do it? I don't see why not. There is enough room between the V-groove and the fan itself.
Posted on: 2015/5/1 21:39
I can mill a profile but want a lathe for doing the Belt races.
Posted on: 2015/5/2 0:47
Parler @MDMachine
I could produce these if there is enough interest, you would have to use a steel crank hub as strength is required to avoid stress fractures. Here is my drawing i did this morning, I may also consider producing these for other engines if sample crank pulleys are supplied
jpg  flat6 pic.jpg (24.51 KB)
15999_55442d137f1c1.jpg 700X980 px
Posted on: 2015/5/2 1:24
Edited by supercharger on 2015/5/2 1:47:22
Edited by supercharger on 2015/5/2 2:46:32
Edited by supercharger on 2015/5/2 2:48:04
Edited by supercharger on 2015/5/2 2:49:12
Edited by supercharger on 2015/5/2 2:50:36
