engine question
guys !
what
Posted on: 2001/10/30 4:52
Re: A15 engine question
teh only things you should have to do is put your engine mounts on it
thats it.
by the way guys i still have my ute i'm parting off.
A15, custom suspension the whole works
Justin
Posted on: 2001/10/30 11:14
From Good Old Knockfull, Tennessee, USA
The A15 is the same bolt-in as the A14 in all aspects. All mounts are in the same place and the trans bolts up the same. It is
a bolt in swap.
Mareo
Posted on: 2001/10/31 8:11
Quite a regular
Not quite - the block is slightly taller. You'll probably be able to get away with it but the exhaust has to go just a little bit higher.... If the exhaust has ever been modified or
changed (or not hung correctly, or given a whack to move it, you may find out now.
If it's an issue, all that will have to happen is about an inch cut out and then welded back in in the pipe to fix it. $10 change at an exhaust place - driving it down there may be
noisy though....
Posted on: 2001/11/1 3:37
