Speed Sensor
Hello,
Wondering if anyone could assist me. I have a Datsun1200 with CA18DET conversion. The speedo stopped working, but the tacho and other instruments just fine.
From the ECU i am getting 12v on pin 53 which i believe to be the speed sense to the speedo cluster. Im not sure how to troubleshoot it. If anyone has any pointers or has encountered similar issue would be great.
Standard CA18 5 speed manual.
Thanks Rory.
Posted on: 2015/5/9 7:01
Re: Speed Sensor
The speed sensor is not needed for the CA18DET. You can remove it and fit a cable drive from a bluebird or other 71B/71C vehicle. The speed sensor is there 1) for the speed limiter, and 2) on 'overrun' it will fuel-cut for emissions control.
Or, if you have already fitted an electric speedometer to the 1200, then it will be needed ...
Posted on: 2015/5/9 7:47
Re: Speed Sensor
Thanks for the info.
It does have a electronic speedo, so would be needed. But, the speed sensor would go to the ECU, then output to speedo, correct?
Posted on: 2015/5/9 8:09
Re: Speed Sensor
From MOOROODUC. Victoria
What speedo are you using?
I have a CA18DE conversion in my ute that runs the Silvia cluster (and most of the silvia loom)
pin 53 should be yellow/green and runs to pin 7 on the silvia white plug(M47) at the side on the gauges.
this is the signal wire - the power will fluctuate depending upon the speed you are going (an oscilloscope would show the wavelengths for different speeds)
I hooked into this wire for my cruise control
Posted on: 2015/5/9 8:14
Re: Speed Sensor
woohoo!
Posted on: 2015/5/9 8:29
Re: Speed Sensor
Speed Sensor Signal Check
1. Remove speed sensor from transmission.
2. Turn speedometer pinion quickly and measure voltage across the two pins
Posted on: 2015/5/9 11:01
Re: Speed Sensor
Cool thanks, i will investigate further.
Posted on: 2015/5/9 11:08
Re: Speed Sensor
Do yourself a big favour and download the Silvia workshop manual "s13.pdf" get the one that is 26,955KB
David
Posted on: 2015/5/9 13:19
Re: Speed Sensor
Thanks David.
894 pages of pleasure haha.
Posted on: 2015/5/9 13:46
Re: Speed Sensor
The pleasure will come when you find out that it does not contain everything you need to know.
Posted on: 2015/5/9 22:41
