datsun 1200 brakes ca18et conversion
From morwell vic
can any one let me know how the brake boster is set up for a ca18et conversion what master cylinder is used and where it how mounted.
thanks
Posted on: 2004/6/8 3:32
Re: datsun 1200 brakes ca18et conversion
From Canberra
A 180B brake booster can be used...
Posted on: 2004/6/8 4:42
Candy Apple Red CA18DET Ute
From Warwick, QLD
I used a LA/LB Lancer booster and master cylinder combo (same one as datto_dude) mine was a direct bolt up providing you get the adapter part from the lancer that bolts to the firewall.
It's a great booster. it fairly long and sits very snug next to my CA18DET. Although with any booster you will have alot of troubles trying to mount an (in engine bay) clutch master for the CA's clutch system.
But one thing I saw at my mech's workshop yesterday was he had a Nomad up on the hoist and it had a stumpy skyline box, but had an adapter setup to run a clutch cable, and not a hydrolic system, quite interesting.
Cheers
Damo
Posted on: 2004/6/8 5:02
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
From wodonga, victoria
do stanza front brakes pass the engineer for a CA18DET conversion or arent they bigger enough?
Posted on: 2004/6/9 4:36
From Mandurah, Western Australia
That's what I used front and back to satisfy the engineer. When its registered and I have driven it for a while Ill modify this setup.
Bigger Brakes
Jarrad
Posted on: 2004/6/9 13:21
