can someone see the cam pick ups on this twin cam setup?
Its a mazda and nice to see something different
rather than crankshaft cas using custom cam one
https://www.youtube.com/watch?v=4AtudzdgaA4
Posted on: 2015/6/1 8:21
Re: can someone see the cam pick ups on this twin cam setup?
Do you mean the Camshaft Position Sensor (CPS)?
http://youtube.com/v/4AtudzdgaA4
It looks like he mounted a CPS right over the right-side Cam sprocket
Posted on: 2015/6/1 9:23
yep CPS thanks, is it using a magnet?
Posted on: 2015/6/2 0:02
I don't know what he's using on that custom engine. But in general, CPS uses a magnetic sensor or an optical sensor (e.g. Nissan Optical CAS).
The sensor here is a magnetic type. The third wire suggests it has an amplifier built-in making it a hall-effect subtype.
Because it is a single sensor, it can only detect one thing (e.g. Cam Position or Crank Angle, but not both).
combo unit - Crank Angle Sensor/Cam Position Sensor
* Mazda B engines used either magnetic version Combo sensor or mitsubishi Optical version
These are fitted on the back of the cylinder head on Miatas.
Posted on: 2015/6/2 1:00
Correction, apparently on Miatas, the single sensor is per Mazda a "CRANKSHAFT POSITION SENSOR". The combo unit per Mazda is a "CAMSHAFT POSITION SENSOR".
Not sure why Mazda would use both, but they do. If you use a Haltech or a Megasquirt ECU, the combo unit is all you need.
18230 SENSOR, CRANKSHAFT POSI. NO.1
18230 SENSOR, CAMSHAFT POSI. NO.2.
Mazda parts
Posted on: 2015/6/2 1:35
Ah, two sensors were only used 1996-1997.
this is interesting:
'96 to '97... The fact that Mazda called them both a CPS was not helpful.
Of course, the old fashioned Miata enthusiasts were still calling a Camshaft Position Sensor (CPS) a Crankshaft Angle Sensor (CAS) adding the the confusion as there was now a real crankshaft angle sensor with the name Crankshaft Position Sensor.
Miata.net: CAM Position Sensor / Crank Angle Sensor
Posted on: 2015/6/2 2:03
