RCA spacer problem ?
From New zealand
I've fitted some new bits to my 1200 ute b122
I fitted up Maddat 22mm castor rods
120y swaybar and a set of techno toy rca spacers ..... After doing all this I fitted the wheels and the steering arms are hitting the rims !!
My front end set up is standard 120y struts no camber tops with lowered king springs and s13 front calipers and rotors.... Body is empty no motor
Has anyone had this problem before ?
Posted on: 2015/6/15 9:53
Re: RCA spacer problem ?
From Melbourne, Australia
Wheel size? Putting steering arms on above or below spacer?
Posted on: 2015/6/15 9:59
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From New zealand
14x6 inch rims and putting the steering arms below spacer ... The calipers are close to the arm aswell but still has around 5mm gap !
Posted on: 2015/6/15 10:16
Be aware take care avoid life in a wheelchair
Dattos - 1200 ute 4agze, 1600 L18 twin Su, 1600 ca18det
Current - building a ca18det 1200 ute and drag 1200 ute undecided on the donk !
Sounds like your wheels are wrong offset. A 5 mm or 10 mm spacer should do it (but not legal in some states).
I've only seen RCA designed to go between the steering arm and the strut:
Posted on: 2015/6/15 11:11
From New zealand
Yea that's how my set up is ..... I might have to try the spacers but first ask the engineer !! And hopefully they don't push the wheels out to far from the guards !! Do you think I need the RCA if I'm lowering the front by 25mm ?
Also could I change the steering arms ? I assume it still has the standard ones ...
Posted on: 2015/6/15 23:43
From Brisbane, Australia
That's a pretty normal problem after fitting RCAs.
They're not needed for 25mm lowering.
Posted on: 2015/6/16 0:57
