a14 conversion
From Tracy ,Ca
does anyone have any pics of modified mounts for installing a14 into a 1200
Thanks Bob
Posted on: 2004/6/8 21:27
Re: a14 conversion
From Brisbane
sorry bobs1200 im just adding another question here....
Just wondering regarding what parts can you re-use from A12 in doing the A14 conversion
is the flywheel, clutch, starter, alternator the same?
Posted on: 2004/6/8 23:08
Re: a14 conversion
From Perth, Australia
Hi Razor...
All of those parts are interchangeable. I just replaced the A12 in my 120Y with an A14 and carried all of those things over. Especially the flywheel as it is significantly lighter than the 14's, thus giving you a more responsive engine.
Anton
Posted on: 2004/6/9 0:17
1974 120Y Coupe
40 thou overbored A14
32/36 DGV Weber
5 Speed Gearbox
New Interior (in the making)
My website
Re: a14 conversion
From Brisbane
thanks for that...
that just saved me a few $$$
Posted on: 2004/6/9 2:18
Re: a14 conversion
The good news is that you do not have to modify the motor mounts or towers. You only need a flat plate with a couple drilled holes.
right side
left side
Posted on: 2004/6/9 2:45
Re: a14 conversion
From Perth W.A
what i did was use the engine mount that is bolted to the passenger side (aus) from the a12 and put it on the A14 and it all bolted up fine.
i think thats what my mate did in his 1200 ute
Posted on: 2004/6/9 3:23
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
Re: a14 conversion
From Brisbane
For my installation I think mine bolts straight on the stock engine mount cos I got a sunny
Posted on: 2004/6/9 3:26
Re: a14 conversion
From Sydney
heres another shot. you can use the same mount for both left and right.Open in new window
Posted on: 2004/6/9 3:44
Street Tail Dancers
1200 coupe - A14
Re: a14 conversion
From Sydney
yeah im pretty sure a14s and 15s bolt straight into sunnys and 1200 utes
Posted on: 2004/6/9 5:18
Street Tail Dancers
1200 coupe - A14
Re: a14 conversion
From USA
The original engine mounts are pretty wobbly for the A-series engines. Are there any mounts available that were made of denser rubber? What do rally cars use?
Posted on: 2004/6/16 1:08
