« 1 (2) 3 »
Re: N14-15 Radiator swap - Done :-D
unfamilia wrote:
should be same as a series, im using n13 one and its all good for fittings
So mik standard a series hoses fit an n13 radiator? What about n14? Looks like the original post the owner used "universal hoses"
Posted on: 2013/12/8 15:44
Long time ago jeff. I think they almost did but microwaved them to fit and top one I had a temp adaptor in line so it needed to be longer to reach
Posted on: 2013/12/8 20:47
Does anyone have a more detailed picture of how to mount the N14 radiator?
Posted on: 2015/6/29 22:12
they have pin mounts top & bottom. Look at one in the wreckers and it's obvious what to do.
Bolt the factory grommet brackets to the core support rail. One bolt per bracket is fine, it's what GM and Ford do.
N14 Radiator Installed
jpg  24188_.jpg (182.11 KB)
174_5591c79e17659.jpg 1280X960 px
Posted on: 2015/6/29 23:33
Thanks!!! Are the mounts readily available or are they a junkyard item?
Posted on: 2015/6/29 23:39
Readily available in the junkyard. Used by most 1990s automobiles.
Posted on: 2015/6/30 0:00
From melbourne
Is a radiator conversion realy necessary in a stock a series?
Ive never over heated my a12 with the stock radiator.
Posted on: 2015/6/30 0:34
For stock A series, no. But they do run hot with some upgrades. I mostly need this radiator because my radiator support panel was cut and this will fill the gap nicely. Plus its a better radiator than my 35 yr. old piece
Posted on: 2015/6/30 0:53
Posted on: 2015/6/30 1:10
N14 aluminum radiator is less expensive than a 1200 radiator
Posted on: 2015/6/30 1:34
« 1 (2) 3 »
