B210/120y manual conversion parts + other parts
From south coast nsw
Convert your mint auto b210/120y with these reasonably low km parts ,
Nice 56a 4speed gearbox, Manual Pedal box inc firewall seal, clutch cable, good clutch assy inc fork and bearing carrier, flywheel n bolts , Spigot bearing, sandwich plate, gearbox mount, speedo assy ,speedo cable, reverse light switch, starter motor, tail shaft ( this is not the best but will get it moving if needed), centre console n brackets, the little plate thing near shifter on tunnel, all bolts (original) needed I will provide .
probably more but I can't think of what else is there. Some parts listed u may not need like starter motor(auto n manual may be the same?) dd will know anyway.
Looking for $500 for all,
or $300 for everything except the gearbox .
Also have a b210/120y brake booster in good order $120
B210/120y factory tacho $80
B210/120y coupe wiring harness $20
B210/120y gearbox tunnel $20
B210/120y steering column $25
I Have a few other b210/120y parts left Il dig em out n post up when get time.
May do cheaper if your polite .
Pick up Scarborough nsw or I can deliver within about 60kms for small fee
best to text me on o4o1937684- nick
Cheers
Posted on: 2015/7/15 16:01
Re: B210/120y manual conversion parts + other parts
From Melbourne,Australia
Im chasing the center console brackets if you want to sell separately?
Posted on: 2015/7/15 22:56
Oh dude I really would prefer to keep the whole lot complete so someone can have a complete setup. I do have another console but I'm not sure if it has brackets with it. Il have a look this weekend and If I do find some il pm u .
I fitted a 120y or sunny console to my 1200 years ago and I'm almost certain i used the original 1200 brackets . so maybe its possible to use 1200 ones? (Maybe easier to get)
I can compare the two for you but and see.
Posted on: 2015/7/17 1:09
All good mate got one coming now thanks anyway.
Posted on: 2015/7/17 6:54
