Lowering 1200 ute
From NSW, Australia
Anyone who has lowered there 1200 more than 2 inches in the rear i want your advice.
I have 2 inch blocks in the back of my 1200 ute and i wanted to go lower. At least another inch! i found 3inch lowering blocks for $300 inc postage but i didnt want to use blocks that big. Is there lowered leaf springs i can buy and install myself. i have been looking to get my set re done, but its becoming a rare thing? surely it can be that difficult.
Posted on: 2015/7/27 4:58
Cheers,
Big D
Quadruple Crown in 1980, the year my 1200 was Built.
Re: Lowering 1200 ute
This is what you get with 3" lowering blocks:
Instead, remove the blocks and have the springs reset by a truck spring company.
Posted on: 2015/7/27 6:13
From Mordialloc Victoria 3195
OR you can take the bottom heavy helper spring off ( too bouncy if your not loaded anyway), and flip the top longest spring over so the eyes are reversed.
You'll need to make up another spring retainer band and knotch out the front spring eye mount a little to take the now upside-down eye. The back will be ok.
Also need to shave your bumpstops down by half , into a point to gain a little travel back :)
This also looks better than your spring hanging down past the body line
Posted on: 2015/7/27 9:05
keep it simple
You could try Lowering Springs, but it's cheaper to have a truck shop reset yours.
Posted on: 2015/7/27 22:46
From NSW, Australia
Ok a few option there, i have heard of flipping the leafs over before.But im going to try and get mine re sett first or buy a set already done.
Are those ones in the pic new or a set you had re done ddgonzal?
Posted on: 2015/7/28 2:58
Cheers,
Big D
Those were the new $58 units here in USA, which aren't sold any longer.
Maddat and King sell similar. See Lowering Springs
Posted on: 2015/7/28 3:02
From NSW, Australia
Ok i have 2 options. So i thought i would share what i found here in case anyone else is looking at this also.
1200 ute springs to Reset Quoted $355p/pair + U bolts.
Or pre made Lowered MadDat Springs for 1200 ute @$500 pair + postage + U bolts.
I have been told the original springs when reset will sag after 12 months and can cause bad tramping. If anyone has had this done before and can comment on there experiences that would be great?
Posted on: 2015/7/30 2:50
Cheers,
Big D
From Gold Coast Queensland, Australia
I put in reset leaf springs with 2" lowering blocks.
Running 14" wheels with 55 profile tyres.
The guard, viewed from the side, sits 15mm above the top of the tyre.
No probs with sagging or axle tramp.
The Maddat spring looks straighter than mine (lower)
Hope this helps
Posted on: 2015/7/30 10:07
1200 ute
L20b
From NSW, Australia
I would like to go with a 3 inch drop in the rear but with out the blocks. The $500 maddat ones sound good but after seeing a pic there not low enough (for what im after) Thanks for the info guys ill see how i go. A few options here to think about.
Posted on: 2015/7/31 12:51
Cheers,
Big D
From Brisbane
BigD I have just installed some maddat leafs in my ute. rubber close to guard height with koni adjustable shocks. 205/50/15's Not the best picture, will get another once i get my car back from workshop next week. This red ute had maddat leafs i think too
jpg  e85 station.jpg (156.58 KB)
13026_55bc31c67d983.jpg 800X600 px
jpg  byte rotor.jpg (157.39 KB)
13026_55bc329bdb483.jpg 800X450 px
Posted on: 2015/8/1 3:44
