Car will fire right up but won't stay on unless foot on gas
Not too shy to talk
From Los Angeles, CA
I've been experiencing a rougher idle the past few days. Now my car will start right up but will not idle unless my foot is on the gas and once it's off it will die immediately. Anyone have an idea of what's wrong? I'm also seeing all of this black gunk around the carb too.
Thanks!
Posted on: 2015/8/6 7:55
Re: Car will fire right up but won't stay on unless foot on gas
Hi Laura, that is a very common problem with automatic transmission cars -- a small air leak will cause those symptoms. So most likely one of the little black hoses on the engine is cracked, causing problems with the air/fuel mixture ... bad enough to cause idle problem, but not bad enough to prevent the engine from running above idle.
If you find a cracked hose, new hose only costs about $1/foot at O'Reilly Auto.
In the photo, #C is missing the hose (fell off). #A hose end is cracked.
As you can see from the photo, black gunk around the carburetor is also common. It won't cause the idling problem.
Posted on: 2015/8/6 8:05
Not too shy to talk
Thanks for the reply! Do you have an image of a diagram of all those hoses by any chance?
Posted on: 2015/8/6 8:11
There are very few hoses on a 1200 (compare to most cars). If you replace a hose, do it one at a time.
I would not replace all the hoses, mine were 40 years old and still good. Just inspect them and replace any that are burned, loose-fitting, or cracked.
Let us know what you find. If all the hoses look good, there are additional things to check. It's pretty easy to check and even if you have a mechanic do the work it'll be good to know.
Posted on: 2015/8/6 8:57
Not too shy to talk
All the hoses are good.
Posted on: 2015/8/6 9:06
The next thing to check is a visual of the fuel float level.
1. Start the engine, run it for 30 seconds, and then turn it off.
2. Under the hood, peek under the air cleaner. The air cleaner doesn't need to be removed.
You may need to wipe grime off the glass to see the level
If the level is near the dot in the center of the glass, that's good. If the level is low, then it needs to be adjusted to solve the idling issue.
Posted on: 2015/8/6 9:16
These are the hoses to inspect:
1. Between Carburetor and Distributor (vacuum advance hose). One end can only be inspected with air cleaner removed from the carburetor
2. Between manifold and transmission (vacuum modulator line)
Connected to intake manifold by short length of hose:
Connected to transmission by a short length of hose:
This can by viewed by lying under the car on the driver's side.
* If it is not connected, shifts will always take place as if the throttle is floored (hard shifts).
* If the diaphragm is leaking (won't hold vacuum) it will leak transmission fluid into the engine, creating smoke.
3. Hoses for carburetor
* Hose for pull-off
* Hose for vacuum opener (if your 1200 has it)
Vacuum Opener is the most complicated system on the 1200. The good news is all that needs to be done is make sure the hoses are good.
4. Hoses for air cleaner
* Hose from bottom of air cleaner sensor to intake manifold
* Hose from bottom of cleaner to the flap motor
5. Thick hose for PCV system. The rubber hose might be soft and squishy, and if it won't stay connected, needs to be replaced.
Posted on: 2015/8/6 9:53
Edited by ddgonzal on 2015/8/6 10:10:25
Edited by ddgonzal on 2015/8/6 10:27:46
Edited by ddgonzal on 2015/8/6 11:25:18
Edited by ddgonzal on 2015/8/6 11:30:09
From Sunshine Coast
I had the exact same problem here too. Rough idle but would be fine when putting foot down.
Also check these couple of things:
Intake manifold bolts are tightend up and no air leaks around gasket
Check fuel filter make sure it doesnt need changing (mine did!)
The thing that actually was wrong with my carb was my Dad (mechanic) said it was possibky crap in the fuel line/jets somewhere.
Try this cause it sounds exactly the same as what happened not more than a week ago for me.
Take of air cleaner.
Start car up,
Go over to your carb and locate the throttle control
Rev your engine up really high til its up around 4,000 revs or so (not drastic but need to rev it a fair bit)
Why your still revving it then put your hand over the intake of the carb (or use a piece of flat cardboard that wont get sucked through, cause i was too chicken to do it with my hand)
Block it off completely, your engine will start to die, let it drop down revs as far as you can without stalling (doesnt matter if it does stall) then see if it idles. Repeat this process 3 times and if there is any crap in the system it should pull it through. I did it 2 times and it completely fixed the idle.
Shortly after i checked the fuel filter and surely enough it had lots of crap in it.
Sounds very similar to my problem so do give it a shot.
Hope it helps! Just thought i'd mention it cause it helped me! Thanks Dad!!!!
If not then probably definately something dd said!
Matt
Posted on: 2015/8/6 12:43
Not too shy to talk
For 3, could you show me where the hose for thr throttle opener diaphram is connected to?
Posted on: 2015/8/6 15:13
Sure thing. The throttle opener is not so much where the hoses go, but knowing that there are hoses and checking each one. If these hoses are not hooked up, don't try to reconnect them -- If the Throttle Opener is not operative, it won't cause an idle problem.
Intake Manifold hose is connected to Throttle Opener Solenoid
Throttle Opener Solenoid hose is connected to Throttle Opener
Posted on: 2015/8/6 19:14
