Challenge is an understatement benny, it's in very poor condition....
Yes the shell is in bad nick nismo1, I didn't realise the 2dr was a common model in SA, I know the coupe, 4dr and truck are common but only saw a couple images of SA 2dr sedans.
cadet1200, yeah spot on there, this is Intergard 269 (International Paints) and is my preferred holding coat. I will be priming with Interseal 670HS which is a high solids base. No idea on the colour, as for the engine, I'm not sure...... definitely A-Series, probably naturally aspirated which is my favourite format.
Anyway, onto the blasting of the rear (I did the inside rear cabin already).
The story doesn't get much better. I'm having to blast with newer, coarser material which is cutting back a fair bit. Some of the metal is so heavily pitted, I may have to resort to something a bit harsher to remove the pitting.
With most the body filler out this side is going to need a lot of work. That last remaining patch will be removed using a wire wheel and most likely some more agricultural techniques.
Some heavy pitting going on here, probably some patch work required to this area.
Showcasing some epic panel repair skills right here.
It is important that deformed edges (from blast pressure) be made right before painting, note the seal channel for the boot here has been bent down.
You can see how coarse the cut is here, there is a much more defined cut compared to earlier pictures. This is because I am using fresh blast material.
Desperately wishing for a NOS panel right about now!
