« 1 (2)
Re: Ca18det flywheel bolts head size
From Goulburn NSW
Hey D cant be done the flywheel sits to close to the block.
Posted on: 2015/9/9 8:14
where the starter hole is you use one
then the other on the same first vice grip
you can also use a bolt at the top of
the block with a small bracket and tube washer
for spacing then other end of bracket to the
flywheel clutch bolt up holes.
Ive split halve a dozen of CA18des this way
both manual and autos.
Posted on: 2015/9/9 13:21
« 1 (2)
