spring strength
From Nyngan, nsw Australia
Hi guys have standard 1200 springs and they don't cut it to carry a CA18,
id like to keep standard ride high if I can,
what's your recommendation in size, strength & brands fulla's :)
Posted on: 2015/11/25 21:21
living is good,.....
Re: spring strength
King Springs KDFS-04, about 40mm longer than stock, only slightly higher rate than stock. So it carries the extra weight of the CA18 at stock ride height, plus you get a smooth ride. You can also make the stock lower spring perch adjustable to fine-tune the ride height.
Posted on: 2015/11/25 22:58
Re: spring strength
You can also raise the ride height by swapping the 1200 strut tops for 120Y strut tops. Raises it about 25 mm?
Posted on: 2015/11/25 23:06
Re: spring strength
Gemini springs are common use too
Posted on: 2015/11/25 23:14
Car free
Re: spring strength
sorry I should of mention they came out of 120Y, wounder if 200B top fit, maybe there bigger in diameter for spring to sit??
Posted on: 2015/11/25 23:19
Re: spring strength
Which part of yours came out of a 120Y? Nearly all Datsun-Nissan tops use the same 123mm PCD mounting, but the two main types are 1200 (using high-pivot tops) and all others. See Strut Tops.
Posted on: 2015/11/25 23:23
Re: spring strength
I have the B110 type, b210 same as 200B top (pic ref)
Posted on: 2015/11/25 23:29
Re: spring strength
From Brisbane, Australia
kings lowered 260Z front coils should do it for a street car.They're captive at full droop in a 120Y strut. 175lbs/in. I used them in my L series turbo 120Y - worked well on the street.
Posted on: 2015/11/25 23:32
Re: spring strength
do Z's have same dimension perch as 120y
Posted on: 2015/11/25 23:37
Re: spring strength
240Z/260Z/280Z have same diameter spring as 1200s. EDIT: 280ZX have much bigger spring perch.
King Springs for 260Z are the small-diameter type, same as the 1200. KDFS-04 is King Spring for 260Z (standard height). KDFL-04 is 260Z (Lo).
Posted on: 2015/11/25 23:50
Edited by ddgonzal on 2015/11/26 0:33:36
