double spring fitment
i'm putting together my refurbished H89 head today.
I'm using this with a new reground cam that came with double springs.
is there anything i need to do special to fit these double springs ?
does one just fit inside the other ? or should there be some sort of centring spacer/washer or something ?
Posted on: 2015/12/8 7:32
Re: double spring fitment
just need eight of these from Nissan
13205-H2300 SEAT-valve spring
Or with some aftermarket springs you may not need them. Check with the spring vendor.
jpg  13205-H2300jpg.jpg (25.37 KB)
174_5666a42e95c11.jpg 300X300 px
Posted on: 2015/12/8 9:25
Thanks DD,
They are from Camtech, i have emailed them....
will let you know...
Andy
Posted on: 2015/12/8 9:55
Nothing extra required with Camtech double springs..
Posted on: 2015/12/9 12:32
From Freo
as DD said, useually they have seats and retainers to suit double springs...
Posted on: 2015/12/10 23:02
A15 PSI Project Motor
'72 CB750k,
From Taupo New Zealand
Nothing extra but you still need to use those steel spring seats as ddgonzal said right? As per original
Posted on: 2015/12/10 23:32
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
Yes, i'm still using the thin steel washers that sit at the bottom if the springs, i assume those are just for wear purposes..
Posted on: 2015/12/11 7:24
The normal spring seats are a special steel washer
The dual-spring seats are the special stepped washer shown in the photo
Good to know that the Camtech springs work with the standard seats
Posted on: 2015/12/11 8:04
