Help! don't know where this part goes! (interior)
Not too shy to talk
From Guatemala
Hello everyone, i am in the rebuilding process of my Datsun UTE, after almost 1 year of disassembly, i am going one piece at a time, now i am stuck in the interior cause in frankly don't remember where this pieces go.
A friend remove them and although i took care of signing every piece, this one was the exception, please!! help!!
Hint: i found them in the same bag as the ashtray screws, they are going probably close to it
jpg  pin.jpg (199.30 KB)
6145_566f444244fbc.jpg 640X496 px
Posted on: 2015/12/14 22:36
Re: Help! don't know where this part goes! (interior)
From Sydney, Australia
Hey mate.
The black piece holds the cable onto the heater tap.
Also allows for adjustment of heat tap control
The washer and clip.
Also go with the heater box
Connecting control rod to heater box, room/vent flap
If that makes sense
Posted on: 2015/12/14 23:45
Not too shy to talk
From Guatemala
Man! You rock! Thank You very much for your help! I will be using this same thread for other pieces
Posted on: 2015/12/15 4:20
Not too shy to talk
From Guatemala
hey guys! does anyone know where this bolt goes? into de 1200 ute? it is not from the back chain support of the tail gate, but i don`t remember where it goes!!! help
jpg  Untitled-1.jpg (117.62 KB)
6145_56d515e9b8be0.jpg 1540X1352 px
Posted on: 2016/3/1 4:10
I think it is the chain bolt, at top
But what is that hook thing for?
Posted on: 2016/3/1 5:28
Hard to tell what size that bolts is, but looks a bit like a bonnet hinge bolt...although as DD said not sure what that hook piece is.
Maybe if you can give bolt dimension it may help.
Posted on: 2016/3/2 4:53
it's a shoulder bolt, like the tailgate chain upper bolt
This seems to show the hook put on the opposite direction
Posted on: 2016/3/2 8:26
Yep, confirmed. Your bolt has the hook part bent closed
jpg  H5 Tailgate.jpg (44.69 KB)
174_56d78c13f3a94.jpg 640X480 px
Posted on: 2016/3/3 0:57
Not too shy to talk
From Guatemala
it is weird guys, but i do have both tailgate hooks!!! and this screw has not much rust to think it was from outside. As i told you at first, the guy who helped me does not quite know where it was when he removed it. :( but could it be inside engine bay???
Posted on: 2016/3/4 3:53
Datsun Project.
Not too shy to talk
From Guatemala
i will give you right dimensions! and thanks for your help!
Posted on: 2016/3/4 3:54
Datsun Project.
