Coil over kits for 120Y ?
Looking for a coilover kit or already made coilovers for my 120Y
Posted on: 2015/12/14 9:02
Re: Coil over kits for 120Y ?
I can do both
Posted on: 2015/12/14 9:45
Car free
Coil-over-strut. Any rate spring is available. You can lower the spring seat and/or adjust camber.
For maximum camber adjustment, get small-diameter springs, Ground Control has fully adjustable kits for $219 USD a pair. Get their 1200 kit which works with 1200 and 120Y.
Posted on: 2015/12/14 9:56
From Vic, Australia.
Hey dd what's a good Spring rate for daily driving in a 1200 ute?
Posted on: 2015/12/14 10:31
92 lbs/in is a great rate for comfort and control. Use a high quality strut shock valved for the 1200 -- like the Nissan unit available from Bprojects or new-datsun-parts
If you have lowered the ute, then you'll want a higher rate spring so that it won't bottom out so easily. If you have lowered the ute 3" then you'll probably want 250 lbs/in
Posted on: 2015/12/14 12:20
supa whats the price for both ?
thanks for the help dd !
im from Australia, i messaged Ground control to see if they can ship to me in Australia, they said they would get back to me tomorrow
also found these http://www.otomoto.com.au/p/4116532/hsd-45mm-sleeve-kit.html
my friend made some coil overs with these and had s13 camber tops machined to fit with gold mk1 shocks
whats your opinion on that ?
Posted on: 2015/12/15 9:19
See Camber Tops notes about S13
Mad Dat perhaps makes the best Tops for Datsun 1200/120Y, although the Noltec above-bell units won't raise your car up.
Posted on: 2015/12/15 9:24
just read the wiki page, thanks for that :)
Posted on: 2015/12/15 9:38
Vw inserts are no longer available I use n10 pulsar.
I also have cambertops to suit 1200 from techno toy tuning
Posted on: 2015/12/15 9:57
Car free
From Mordialloc Victoria 3195
Just finished fitting the units I got from supafatto using the N10 inserts (80mm shorter) with no preload , helper springs and adj strut tops.
Handles great now.
Recommended Thanks Nick
jpg  P1010098.JPG (153.49 KB)
16236_5670833f4e310.jpg 640X480 px
jpg  P1010097.JPG (151.72 KB)
16236_5670834da7216.jpg 640X480 px
Posted on: 2015/12/15 21:17
keep it simple
