« 1 ... 3 4 5 (6) 7 8 9 ... 16 »
Re: Elrich11's CA18DET 1200 Ute
Nice! How do you preserve the finish? Spray it with clearcoat?
Posted on: 2015/12/19 5:34
From Geelong, Victoria
Santa also came this week with my 15x7.5" Convos (only took 4 months). These with 5" BS and 205/50r15 Mickey Thompson Street Radials fit perfectly. There is little room to spare so hope it is OK under hard acceleration? Hard cornering scrub not such a concern for this car with 145's on the front corners are going to be granny pace anyway. I ended up with about 10-15mm clearance from the guard and leaf spring with the 7.5" rims with +19 offset (5"BS).
A few pics...
jpg  Rims1.jpg (195.34 KB)
17122_5674ee78da6c7.jpg 911X685 px
jpg  Rims2.jpg (195.43 KB)
17122_5674ee83a5817.jpg 1008X756 px
jpg  Rims3.jpg (193.30 KB)
17122_5674ee8f1785d.jpg 958X719 px
jpg  Rims4.jpg (192.22 KB)
17122_5674ee9ee0136.jpg 958X719 px
Posted on: 2015/12/19 5:47
DD - For now I am just using polish. I have some bright and shine wadding that will be handy but otherwise it will be the old fashioned way! Not a big stress as it is a weekend / tinkering car so will be constantly fiddling, cleaning, pulling apart, putting back together etc. anyway. All the bits I have polished are aluminium so they should keep OK for a while.
Posted on: 2015/12/19 5:51
Sorry, lots of updates at once but time is my enemy.
Having the inlet manifold apart I have been toying with the idea of match porting the runners to the fuel rail / butterfly plate. The inner section which houses the fuel injectors matches quite well to the gasket diameter, the manifold runners on the other hand are 2-3mm under size almost around the entire circumference. Now common sense says that opening these will be better for flow with less restriction / obstruction etc, etc. However, is this really a worthwhile exercise for a mild engine? Has anyone on here actually had any measurable results doing this or used a flow bench to compare factory with a match ported manifold? Realistically there will be many other factors limiting power before this in my build, but I feel that it should be a "whilst I'm there" job.
I am not touching the head yet, so is it worth spending several hours doing this or just leave it? Any feedback / opinions? Would love to hear of other experiences.
Also for now I am leaving the butterflies in.
jpg  Runners.jpg (193.41 KB)
17122_5674f72982137.jpg 846X636 px
Posted on: 2015/12/19 6:20
Excellent! That's plenty of clearance. I would say it can go down to 5mm clearance, but then it risks rubbing on corners. Leaf spring move side-to-side a bit when cornering but won't move forward/backward during acceleration (the springs may wrap a bit under hard acceleration but that only causes tramping)
Posted on: 2015/12/19 7:39
A quick Youtube vid on the S13 strut swap. I couldn't find any video footage of setups when I started, so I made one myself. If anyone as any input or suggestions for changes, let me know I'll be happy to refine it.
https://www.youtube.com/watch?v=4szDZIJK8fc
Posted on: 2015/12/26 13:52
Just got an email from Sanjay at Autoteam. He is no longer a VASS member and is following another career. Looks like I'm going to be finding a different Auto Engineer for this project! Anyone got any suggestions?
Posted on: 2016/1/16 6:34
Yeah, good thing you used an Autoteam, so the loss of one employee shouldn't slow them down!
Posted on: 2016/1/16 6:49
Haha, unfortunately they are a team of one.
Posted on: 2016/1/16 6:51
Wow that's a big concern for me as Sanjay was the engineer I was using to!
Let me know who you find....I'll start digging around to.
Posted on: 2016/1/17 5:22
