« 1 ... 25 26 27 (28) 29 30 31 ... 49 »
Re: Turbo EFI A12 for under $1200. Discussion thread
From Melbourne, Australia
nah, will most likely crack up from the weight of the turbo pretty quick
Posted on: 2015/9/16 4:36
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Not too shy to talk
From Olympia, USA
Cherry F-II owner here, looking to jump in this madness. Sikyne you have a PM.
PS, I was formerly known as ericsb210, member since about 2010.
Posted on: 2015/9/23 7:47
So what, who cares.
I have pm'd you sikyne. Hopefully a few more people are keen for this so we can get a good price!!
Posted on: 2015/9/27 2:10
From Ballarat Victoria
I haven't touched this for a while. I retuned the NA setup. It makes 31Kw now. It still has that vapourisation issue at light load. I'm going to take the engine out of the car to fit the turbo and test it on the dyno out of the car. This way I wont have to do a full exhaust to test it and will make it easier to test different turbos etc.
Regarding selling kits.... I don't really want to sell stuff until I can be sure that its all working as planed. The inlet manifold may have to be heated to aid in fuel vapourisation on the single injector setup.
Sorry its dragging out a bit. I do tend to get distracted with different projects!!
Turbo's to test!
jpg  IMG_0677 30%.jpg (153.51 KB)
6746_5692e534d95f2.jpg 581X778 px
Posted on: 2016/1/10 23:12
VIC DYNO HIRE
Intake vapourization issue is one of the oldest engine problems. Originally solved by making a "hot spot" in the intake manifold
Modern solution is either:
* Heat riser intake manfold (exhaust bolts to intake)
or
* Water-heated intake manifold
Posted on: 2016/1/10 23:31
Exactly.. Some engines also pull hot air from around the exhaust manifold, then plumbed in pre air filter.
Posted on: 2016/1/11 2:15
VIC DYNO HIRE
The Datsun 1200 does that for Japan and USA models. It's not for vapourization but is to prevent the throttle blade from freezing. Datsuns "for tropical climate" don't have it.
http://datsun1200.com/modules/mediawi ... le=Air_Cleaner#Anti-Icing
Posted on: 2016/1/11 5:47
That makes sense...When the car was on the dyno, I connected the air cleaner inlet to the standard tin cover on the A15 exhaust manifold. The vapourization problems disappeared. So it must aid that as well.
Posted on: 2016/1/11 6:45
VIC DYNO HIRE
Hey there's one solution. Use a thermo air cleaner say from a newer Datsun. These air cleaners bypass the warm air when throttle is down so they run full cold
Posted on: 2016/1/11 6:58
Sounds perfect!
Posted on: 2016/1/11 7:12
VIC DYNO HIRE
