Flat tops for an a14...
From Leeton NSW
Hey guys building an a14 want it to make over 100hp atw planning on running twin dellortos definitely staying NA having a hard time chasing up pistons was told to go flat tops to raise compression so thats what im chasing anyone know some places that specializes in a series performance parts ? Cheers
Posted on: 2016/1/11 14:36
Get in, sit down, shut up and hang on!!!
Re: Flat tops for an a14...
Stock dished pistons are 9:1 compression. If you go to 11:1 compression that is good for 5 additional HP, so definitely worth it. Also it will run fine on Premium fuel.
peterzekert.com sells A14 flattie pistons
Posted on: 2016/1/11 23:39
From Leeton NSW
ok then will check it out any companies in Australia that specialise in them do you know?
Posted on: 2016/1/12 4:46
Sure. Australia companies charge about double, but you are supporting the local economy so that's good
JP Pistons Australia do a custom A14
Could maybe use Isuzu 4XC1 flat tops if you bore the A14 1+mm OS
* Gemini, I-mark, Piazza
* Chevrolet Spectrum
* $28 each RockAuto.com
* 4 for $79 eBay
They have a compression height 0.1 mm taller than A14 so might work best with a 0.8 tomei head gasket (the Nismo head gasket is 0.6 so that's too thin?). You could also use a stock (thick) head gasket if you aren't too concerned about getting the most hp out of your build
jpg  224-2715.jpg (14.40 KB)
174_56948c014b386.jpg 400X300 px
Posted on: 2016/1/12 5:15
Seems the Isuzu pistons have 18mm piston pins, not sure how those would work ...
Posted on: 2016/1/12 6:25
From Newcastle (NSW)
I have used ACL Mazda E3 pistons with success.
You'll need to bore the rod little end to 20mm (easy job for an engine machine shop), then deck the block to suit the piston height which is a little under the Datsun piston height. I selected to use chrome rings not the standard cast iron rings.
If that is too much compression then you can select the Mazda E5 or the 1.6L MX5 pistons which both have a small dish, I think around 6cc from memory. lots of options...
Posted on: 2016/1/13 3:55
Racecar spelled backwards is racecar!
