USDM B210 uses PB210 large suspension including 232 mm rotors (early) and 245 mm rotors (late, same as Stanza/B310). The calipers are likewise larger. But you don't need new rotors as your rotors can be turned for $20 or so
Calipers for 120Y are readily available in USA as they are the same as B110, however the late rotors use a factory adapter plate to space the caliper out 4 mm. Or, B110 rotors bolt right to the 120Y hubs
Would you be better off going to larger, more modern brakes? Then you can keep the struts you have now and
upgrade to B310/Stanza brakes or 280ZX brakes, or
S13 Brakes. Remember, 120Y struts are same as B110 struts except for wheel bearing size. The hubs are same external size.
Personally, I would choose the Bluehands
280ZX Brake Upgrade -- much larger than S13 brakes, totally bolt-on, and fits under 13" alloy wheels.
Gotta love Datsun, so easy to work with, and so many upgrade choices!
