Twin Weber DCOE PCV Problem/emissions
From Canberra
Hey guys got a quick query regarding to emissions to ensure i pass
So the issue i have is quite simple but quite a pain, i have my A15 fully worked running a redline manifold with twin 45mm webber carburetors i have my crank case ventilation running to a catch can and also have tappet/rocker cover running to catch can and no return line at all just both to the catch can and vent to atomosphere via the filter on the catch can but my issue is in regards to emmisions i need a PCV put inline from the crank case and need a return to intake manifold
Now unfortunately there is physically no chance i can run anything to the redline manifold as it only has a vacuum brake line fitting which is a -3 AN and the crank case vent pipe is massive and i have fit a -10 AN braided to the catch can so my delema is without an airbox how the hell do you run a return PCV system back into the carb's to burn off these emissions
Sigh i hate these emissions rules just let me run the catch can to atmosphere
Posted on: 2016/1/24 7:40
Edited by loosekid on 2016/1/24 12:12:37
Re: Twin carbs crank case ventilation for emmisions
From Canberra
or is it fine the way i have it as my proflow catch can actually has a quenching plate to cool hot oil vapour and turn it into a liquid so it can be collected in the base.
Posted on: 2016/1/24 7:44
PCV is not just for emissions, it keeps your oil more clean than a catch can -- and people have had 52 years to solve the problem of how to use it (PCV came out in 1964)
* PCV connects to the inlet manifold
* crankcase top vent connects to inside of the air filter
Use the -3 AN connection, Tee it, with an adapter hose going up in size to fit the PCV valve. Yes, -3 is small, technically too small for a brake booster, but it works. If your rings are in good shape (not producing excess blowby) there should be no problems sharing it with the Brake Booster port. If you have forged pistons you may have too much blowby when the engine is cold
Drill a hole in the air filter and use a plastic breather hose adapter
Posted on: 2016/1/24 8:22
From Canberra
Well with that said couldn't i merge both the feeds (as they are now) into the catch can and then plum an extraction line from the catch can to the air box no need for the PCV?
Posted on: 2016/1/24 9:31
From Canberra
It makes complete sense and i understand why but having build essentially a race engine that i still want to be able to drive around on the street with a manifold that has no provision for PCV valve it makes it frustrating and a very ugly mess without being able to just use a catch can
Posted on: 2016/1/24 9:40
* Catch can only is passive ventilation
* PCV is positive ventilation -- it makes sure the block is ventilated with fresh air, while catch can purpose is to make sure that the oil is separated out
You can have both, if you set it up right
Posted on: 2016/1/24 10:07
