Dragging rear brakes
From northern 'burbs adelaide
Hey guys, so im running R31 rear brakes with a hydro h/brake and a wilwood proportioning valve. Im having the rear brakes dragging and cant work it out ... ive removed the valve out of the master and checked all that ... so ideas?
Posted on: 2016/1/29 4:26
Re: Dragging rear brakes
From Melbourne, Australia
what have you setup for cable handbrake? nothing to do with that?
Posted on: 2016/1/29 4:49
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Posted on: 2016/1/29 5:12
1200 Coupe Rallycar
No cable brake but its a spring return so its not that
Posted on: 2016/1/29 6:26
Dragging rear brakes has two possible causes:
* Hydraulic problems
* Mechanical problems
The usual hydro problem is the Residual Valve thing in the disc/drum master cylinder.
Less often:
* brake lines next to the exhaust system
* collapsed flex hose
* sticking Master Cylinder piston (not returning fully)
* Master Cylinder over-full
* Proportioning valve sticking
* Master Cylinder free-play incorrectly adjusted
* Brake Booster push-rod incorrectly adjusted
Mechanical problems include:
* parking brake adjusted incorrectly, even with no cable hooked up this can cause dragging
* Caliper piston sticking
* Caliper sliding surfaces binding
* Bent or misaligned caliper or caliper bracket
* Dry wheel bearings
R31 rear disc parking brake adjuster
Posted on: 2016/1/29 7:18
Its both sides and if left sitting they back off slowly so im assuming its hydraulic
Posted on: 2016/1/29 9:28
Quite a regular
Something to do with the hydraulic handbrake master cylinder? A pressure residual valve in that?
Posted on: 2016/1/30 6:30
