Ute: connecting main harness to rear harness
Can anyone show me how to connect the main harness on the dash to the rear harness for the rear lights, license plate lights, etc... on a 1200 ute?
I know there is a flat looking section of wiring that is hidden under the carpet but where does it connect to? I assume it is concealed in the body behind the cabin?
Thanks.
Posted on: 2016/4/4 18:32
Re: Ute: connecting main harness to rear harness
The flat wire is part of the Body Harness
* 24012 Engine Room Harness (includes front light wires)
* 24013 Instrument Harness (dashboard)
* 24014 Body Harness: goes from firewall to rear of car, under floor mat
* 24015 Tail Harness (rear lights)
Posted on: 2016/4/5 0:25
The rear harness comes in near the bottom seat belt mount on the Drivers side (RH Drive). There should be a rubber grommet with a connector coming through it. This should plug into the flat multi-cable you mentioned, which is normally stuck down to the floor and heads to the main harness.
Posted on: 2016/4/5 1:57
Yes, the flat wire (Body Harness) has only three connections:
* To Instrument Harness
* To Rear Harness
* To Room Lamp harness
The front corner is where Body and Engine harnesses plug into the Instrument (not shown in photo) harness. LHD photo (reverse for RHD)
Posted on: 2016/4/5 2:03
The main harness is the Instrument harness, no? Rear harness is called by Datsun "Tail Harness"
What connects the two is the flat-wire Body Harness
This photo shows where the Instrument Harness connects to the Body Harness (yellow arrow goes to Body Harness I believe for the mid-model ute)
jpg  Instrument Harness.jpg (120.75 KB)
174_57031a58a8aa3.jpg 1024X768 px
Posted on: 2016/4/5 2:49
Ok awesome, thanks for the info guys. I'm putting the rest of the wiring in this week.
Posted on: 2016/4/5 4:28
