« 1 (2)
Re: It was a Bad Day
From Sri Lanka
Hi 1200rallycar
Thank you, i will check it first
thanks
regards
sumith
Posted on: 2016/4/4 9:02
That's what happened to my 1200
Posted on: 2016/4/5 0:44
From Sri Lanka
Hi Guys
I checked the castor rod it is not bent or crooked, is it the problem with my chassis have gone backwards ?
thanks
regards
sumith
Posted on: 2016/4/8 7:23
Check where the rod fastens to the front of the car. It may be loose there
Posted on: 2016/4/8 8:10
Also check for unexpected movement of tire/wheel. Attempt to roll the front tire and see if it moves even though car does not move
Posted on: 2016/4/8 8:18
From Sri Lanka
Hi DD
Rod was tight enough to the front of the car, Ok Noted I will check the wheel movements
thanks
regards
sumith
Posted on: 2016/4/8 8:36
« 1 (2)
