Fuel Smell Inside the car when tank is Full
From Sri Lanka
Hi Guys
I have a bad fuel smell inside the car when my fuel tank is full specially when driving on bumpy and curved roads, do you also have the same issue ? , my fuel tank lid looks good no damage or any defect but yet it smells,
what you guys suggest to prevent this ?
thanks
regards
sumith
Posted on: 2016/4/12 4:34
Edited by Sumith on 2016/4/12 4:50:51
Edited by Sumith on 2016/4/12 4:51:50
Re: Fuel Smell Inside the car when tank is Full
Some 1200s have that problem, some do not. It can be caused by many things -- see for a list of possibilities: Fume Control
A 1976 B210 (japan model) is an EVAPO model and should have a Fuel Cap with a spring it it
Posted on: 2016/4/12 4:50
From Sri Lanka
Hi DD
according to Wiki b210 has 40 ltrs fuel tank, i filled it last night it was 37 litres i am pretty sure it had more then 3 litres is it possible to put more than 40 ltrs ? how much of fuel ltrs can be put inside b210 sedan tank ?
thanks
regards
sumith
Posted on: 2016/4/12 4:52
1000 liters can be put in, but after 40 the excess will run out the filler tube. Most petrol dispensers will automatically shut off if that occurs
If there is a leak, it may run into the car (inside the trunk, aft of the rear seat). Open the boot and examine closely for tell-tale odors
Posted on: 2016/4/12 5:18
