H165 diffs and extras
From Sydney , NSW
Hey crew,
I have some treasures to sell that have to go - my S15 project demands a constant supply of coin 😉
H190 Diff:
4.625:1 Alloy housing. Mint condition gears - $350 plus freight
H165 Diffs
4.625:1 Steel housing. Very good condition - $300 plus freight
4.875:1 Steel housing. Welded centre, a bit worn but usable - $200 plus freight
Sunny booster and master cylinder. In storage for years. Clean but may need a kit in the master as a precaution - $100
260z close ratio gearbox. Oily but complete. Bought as a spare years ago as these are getting rarer and rarer. Seems fine by hand but worth a check before installing. Bargain at $250.
Stanza H165 diff housing. Coil platforms replaced with coil over threads, bluebird discs, callipers and alloy backing plates. 23 spline axles included but no centre.
Was in my circuit car (sunny coupe) and had 3/4 degree neg camber and 3mm toe in bent into it by a differential specialist. Rear of housing has been extended to allow greater oil volume but therefore is best used with a pump to ensure correct pinion lubrication. Lot of work gone into this housing and was removed only to upgrade to H190. $350 ONO will secure this hard to get item.
All items located Picton / Narellan NSW.
Call me business hours only on 0415 one zero seven 090
Cheers.
Posted on: 2016/4/22 12:51
Edited by R-fastmotorsport on 2016/4/25 0:44:43
Edited by R-fastmotorsport on 2016/4/26 10:50:09
All torque, no traction
A division of "My mate's ....." engineering
Re: H165 diffs and extras
From Sydney NSW
Pmd, re booster.
Posted on: 2016/4/23 1:04
There maybe faster ways to go...
But I'm never in a rush
260z box and ally diff centre
have to work out freight
Posted on: 2016/4/23 1:15
Edited by D on 2016/4/23 1:35:50
From Sydney , NSW
Hey guys,
Great response!
PM replied on the booster.
Get back to me quick D, as the alloy centre is hot property!
I also have two other alloy housings. One for a 23 spline LSD I will assemble for sale and another that is left over from a ruined pinion. Yell out if it is of use.
I also have some Stanza LCA and struts around I think also.
Cheers.
Posted on: 2016/4/23 9:32
Pmd
Posted on: 2016/4/23 12:35
Edited by D on 2016/4/23 13:59:26
From Taupo New Zealand
Did you get my pm?
Posted on: 2016/4/23 20:22
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
From Sydney , NSW
Hey guys,
Great response!
Alloy 4.625:1 and 260z box still available. Interest in steel 4.625:1 and booster but still available until paid for.
Cheers.
Posted on: 2016/4/25 0:43
Edited by R-fastmotorsport on 2016/4/26 10:51:22
From Sydney , NSW
Hey Crew,
Sorry for the confusion but original ad has been modified - stupid mistake by the seller 😉Been around modern cars for too long.
Hey Matt, sorry mate but spare alloy housing is H190 also 😕
Cheers.
Posted on: 2016/4/26 10:55
d0nt understand th0ught I had first dibs 0n b0x then pmd u s01d it
n0w avai1ab1e again? 1et me kn0w p1s have $ waiting
Posted on: 2016/4/26 15:49
From Sydney , NSW
Pm sent.
Posted on: 2016/4/27 11:11
