« 1 ... 9 10 11 (12) 13 14 15 ... 18 »
Re: Kermit the beat up Sedan
Yeah that rain belted down and the thunder certainly got my attention (that and the dog going nuts!).
I thought I was hard done by when I opened my garage door to find that water and a layer of silt had found it way across most of the floor...looks like you copped it worse David. Where did all the missing corrugated iron end up?
P.S. I owe you, so if you need a hand nailing it all back on send me a PM.
Posted on: 2016/5/1 16:13
From Mordialloc Victoria 3195
Skylights are all the rage these days
Posted on: 2016/5/1 22:57
keep it simple
From MOOROODUC. Victoria
Got the shed 're-roofed' (did it myself with new tin and poly sheets). It came up a treat but all my electrical stuff is away getting cleaned (part of the service with the insurance). Now I have to wait for the electrician to do the hoist and switchboard....
So, decided to build another 7m x 8m shed nearer the house; deposit went down today - Kermit will get a new bedroom! Should be up in a couple of months depending on permits and building etc. woohoo
Posted on: 2016/6/18 8:33
New shed hey..room for even more Datsuns.
Hope your putting in a spray booth!
Posted on: 2016/6/19 11:28
New Shed Started!
The DAT-CAVE will be up this week - concrete floor will need to wait for some warmer weather.
jpg  shed1.jpg (121.38 KB)
8710_57b0377ab7e51.jpg 816X612 px
jpg  shed4.jpg (85.76 KB)
8710_57b037e76c111.jpg 816X612 px
Posted on: 2016/8/14 10:20
Sweet
Posted on: 2016/8/14 14:06
Car free
With two hoist you'd get 6 Datsins in there easy :0
Posted on: 2016/8/17 8:23
keep it simple
IT LIVES! ... sort of
Got another starter motor last week and put it in today.
First victory - it cranked over
Second Victory (after some 'encouragement fluid') - it fired a few times.
woo hooooooo !
Wouldn't keep going though. The fuel pump is not working properly.....
IT SUCKS BUT IT WONT BLOW .... should I replace the pump or is there an easy fix?
this is the encouragement fluid
jpg  13168.jpg (22.25 KB)
8710_590d7fd11530e.jpg 400X400 px
Posted on: 2017/5/6 8:48
Easy fix, replace the filter (will only fix a clogged filter). I had an EFI car stop running due to clogged filter. I drained the filter on the side of the road and was able to drive it home, then I replaced the filter and it started running perfect
Posted on: 2017/5/7 4:28
It's already a new filter.
I pulled the fuel pump apart gave it a bit of a clean and blow out with air. Put it back together again and it seemed to suck and blow right with manually operating it but when I put it back on the car and cranked it over nothing came out the outlet pipe. It was doing something strange ... the fuel level in the filter seemed to be bubbling up and down. YES the pipes are right for inlet and outlet - I checked
Any help appreciated .... it did work (4 years ago)
Posted on: 2017/5/7 9:00
