WTB : 60A B310 Gearbox Xmember
Hi there,
Thought I would give it one last shot before going down the custom route.
I am after a gearbox crossmember from a b310 facelift coupe which is suited to a 60a 5 speed box so i can mount 60a into a b310. None of the after market products are suited to my application as they are intended to fit the 60a into a 1200 which im not doing.
Thanks
Posted on: 2016/5/31 14:31
Re: WTB : 60A B310 Gearbox Xmember
From Snohomish, WA USA
Do you have a welder? Make your own. Set you engine and tranny in place and make it. That's how I did it. That's how I've made all my supports.
Posted on: 2016/6/1 5:52
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
I've got a 60a dogleg box in my sunny and I remember I did it with the crossmember that the box came with(sunny wagon)
And the standard one.
From memory I just had to open a hole up or something simple?
Posted on: 2016/6/1 8:50
A12-powered Sunny used a different crossmember. 60-series 4-speed crossmember is nearly the same as 60A except it needs 20mm spacers to work with the 60A. The 60A crossmember is unique and fits the best
Sunny has three holes in the body, so any of the three B310 crossmembers can be bolted to the car
Posted on: 2016/6/1 9:44
See I modified my 4speed cross member that was on my 56A box to fit the wider mouting on the 60A gearbox, but when bolted the modified mount to the gearbox i found the bolt holes on the mount didn't line up with the bolt holes on the chassis on the chassis (should have measured first lol)
So that's why I'm looking for the cross member that should go with a 60A
Posted on: 2016/6/1 23:18
someone must have a 60A crossmember lying about a shed or in an old Sunny
Posted on: 2016/6/1 23:52
I have a 60a 5 speed crossmember
edit: mine is for a 1200
Posted on: 2016/6/1 23:54
That's what I'm hoping for ddgonzal
Cheers guys
Posted on: 2016/6/2 8:18
Any pics of the xmember you have? Cheers
Posted on: 2016/6/2 12:16
Last Bump lol
Posted on: 2016/6/6 13:26
